Author Topic: LOTS AND LOTS AND LOTS OF HUM!!! HELP!!!  (Read 13255 times)
itamar101
« on: April 05, 2012, 11:21:01 PM »
I recently got my tech to installed a Gibson P94T Bridge pickup in my les paul studio and i quite like it but there is a big problem. Since then there's been loads of hum from both pickups (Humbucker and P90) and i cant stand anymore especially because i play with high gain and gain only makes it worse.
Anyway there is a crazy amount of hum and its making me mad, after taking it back to get fixed he only made it worse and after taking it back again it was back to where it was before he made it EVEN worse, so still loads of hum. The hum goes away when I touch the pickups or the input jack so the obvious assumption would be that it isn't grounded properly but after taking it back 3 times and him saying that he doesn't know what the problem is then there might be something else to it. I've opened it up and taken a look and and all of the connections seem strong but TBH I'm no expert with electronics so i need help.
Please take a look at the pics and tell me whats wrong. I plan on buying BKPs very soon but there is no point buying something as good as BKPs for a guitar that i hate playing because of a stupid amount of hum.
I have an SSS strat and there is almost no hum from that apart from the natural single coil hum and in the 2 & 4 positions there is ABSOLUTELY NO HUM AT ALL. So the problem is with the guitar.
Man, techs can be idiots sometimes.
Anyway, i'll upload some pics of the wiring.
Thanks in advance for any help.
itamar101
Re: LOTS AND LOTS AND LOTS OF HUM!!! HELP!!!
« Reply #1 on: April 05, 2012, 11:22:42 PM »
[PICS CONTINUED]
As far as i can tell for some reason everything seems to be connected to one volume pot and nothing is connected to any other pots, tone or volume, yet all of the control still function properly.
There's just a big mess on one pot and the rest of them have solder on them but nothing connected.
In fact, i'll just let you guys take a look and troubleshoot the problem.
Frank
« Reply #2 on: April 06, 2012, 12:03:12 AM »
The guitar clearly isn't grounded properly. I usually ask if people have a multimeter handy, check that there is (almost) no resistance between the backs of the pots and the sleeve connection of the socket.
If you don't have a multimeter ... buy one! Although you could maybe try tracing the ground problem by temporarily holding short wires inside to connect all the backs of the pots to the socket sleeve tag. Growing another pair of hands may help here. Finding a competent guitar tech may help even more.
« Reply #3 on: April 06, 2012, 12:08:44 AM »
Was there ever anything soldered to the back of the pots?
I wonder because there is solder clearly there
Gibson are using a printed circuit board with all the tracks already on there (I am not a fan of this arrangement!)
The backs of the pots should also be earthed or at least some part of the pot chassis - Gibson may be relying upon contact with the circuit board - often this is not enough.
Did it hum before the tech did the swap?
If not then maybe he has disturbed something when taking stuff out.
If it were my guitar I would probably choose to get rid of the PCB and just use loose components properly wired up
I;'d use the BKP 550k ohm pots and Jensen caps , and I would screen the cavities too is they were unscreened (I use a special nickel screening paint and it is brilliant)
If my workshop is near you you would always be welcome to bring the guitar in and I'd happily diagnose what ails it.
itamar101
« Reply #4 on: April 06, 2012, 12:27:39 AM »
TBH i never actually opened up the back before i realised the hum (which was after I changed the pickup) so I have no idea how it was wired.
But there was no hum before the pickups swap.
I hope to take the guitar to another tech in the near future because my local tech has obviously done a shite job.
I'm a bit tight on money right now so i'd rather not swap out all of the components to be honest :/
Of course, any more help is welcome :)
« Reply #5 on: April 06, 2012, 01:13:28 AM »
Has he put one of the plugs on backwards and effectively made an earth wire a live wire - so some metal surface is acting as an antenna for noise
JacksonRR
« Reply #6 on: April 06, 2012, 01:51:56 AM »
I'd say your bridge isn't grounded or has a high resistance to ground. That little green box looks like it has the bridge ground wire running to it and that it wasn't soldered half way along the wire originally. Looks like a solderless connection. I'm pointing my blame at it right now especially if you can't actually get that wire out of there. If it was abused before the wire got cut, there may be damage underneath/inside.
And take that tape off please.  Feline's theory might be happening in one of those.
Here's a before picture:
« Last Edit: April 06, 2012, 01:59:42 AM by JacksonRR »
itamar101
« Reply #7 on: April 06, 2012, 09:21:16 AM »
Ok, I'll take the tape of later and upload a photo.
It's pretty crazy how some techs demand Payment to $%&# up your guitar :/
« Reply #8 on: April 06, 2012, 10:33:20 AM »
That is why seeking out a tech with a good reputation is important.
I pride myself on both high standards of work AND good customer service, and instil this in any techs that I train.
It sounds like the earth path has been messed up somehow.
I absolutely hate all these solder-less systems as they are so prone to failure, and to someone who knows how to solder the solderless systems are way more complicated than they need to be.
itamar101
« Reply #9 on: April 06, 2012, 10:41:22 AM »
Oh, the Gibson system is solder less?
So could I attempt to fix it myself (my solder iron is broken and it's a 1 1/2 hour drive to the nearest DIY store cos I live in a small town)?
How do you go about cinjecting everything with these solder less systems?
Frank
« Reply #10 on: April 06, 2012, 12:21:12 PM »
It's not exactly solderless, just all the components are mounted on a PCB which can make it harder to trace a fault. Where are you based? Maybe a helpful BKP forum member near you could assist - or at least recommend a competent repairer.
Frank
« Reply #11 on: April 06, 2012, 12:30:15 PM »
From the photos it looks likt the PCB connectors must be "keyed" so they only attach one way. Although I suppose a really cack-handed tech could manage to force them on the other way round but wouldn't he end up with an out of phase pickup?
itamar101
« Reply #12 on: April 06, 2012, 12:50:26 PM »
I'm in Israel. I doubt that there's anyone on this forums who could help me.
The pickups certainly aren't out of phase. They sound completely normal and they don't have any volume issues either (although the first time I tool it to the tech and he made it worse I couldn't any volume from the bridge pickups anymore there was EVEN more noise, he's fixed that though).
There's a bigger store about 30 minutes away and the guy there really seems to know what he's talking about. I think I'll him out. If not then I'll probably be visiting England in a few months and there's a store that I see doing set ups and changing pickups all the time but they don't sell gibsons so I'm not sure whether they'll know how to use the PCBs.
In that case, is there anybody in this forum nearby Cambridge who could give me a hand? London is probably also ok.
Toe-Knee
    • DIY Audio
« Reply #13 on: April 07, 2012, 01:32:12 PM »
I believe there are quite a few members in or around cambridge on this forum that would be able to help you.
Also im pretty sure anyone that knows that they are doing would be able to figure out that pcb system
http://WWW.BACKLINE.TK
Non Biased Guitar Forum
http://fret.boards.net
itamar101
« Reply #14 on: April 07, 2012, 02:58:03 PM »
Thanks. I'll be posting pics of it without the tape shortly.
