strat hsh with mini toggle wiring
Started by bandmaster188, April 07, 2012, 04:16:27 PM
bandmaster188
hi all, i thought there would be a schematic for this wiring configuration but can't seem to find anything out there.
here's what i'm after.
fender strat with vhii bridge, standard single coil middle, stormy monday neck.
i want to run this setup on the standard five way selector but then have a mini toggle to turn off one coil at the neck and one at the bridge so effectively keeping all the strat type sounds intact.
so with mini toggle off it would be;                         with it on it would be;
p1 bridge humbucker                                             p1 one coil of bridge humbucker
p2 bridge humbucker/single coil                              p2 one coil of bridge humbucker/middle single coil
p3 middle single coil                                               p3 middle single coil
p4 single coil/neck humbucker                                 p4 mid single coil/1 coil neck humbucker
p5 neck humbucker                                                 p5 one coil neck humbucker
please help!
The swamp city shakers
Frank
SHAZAM!
That's with a master tone control, if you need separate tones then just copy those from the standard strat wiring. The diagram shows a switch on the pushpull knob but it's exactly the same set of contacts on a standard switch.
bandmaster188
cheers for that frank.
i'm a little bit unsure how i connect the mini toggle to the volume pot, but will try this out and see what happens.
Frank
the black wire from the switch just connects to the back of the volume pot (or any other grounded point)
