Author Topic: Help needed switching pickups  (Read 1505 times)
Elessar [Sly]
« on: April 18, 2012, 01:25:45 PM »
Okay so I am getting new pickups for my SG and on the side I have decided to switch out some pickups on my Ibanez with the pickups in my les paul.
I currently have nailbomb in the bridge of the ibby and a cold sweat in the neck. I wish for these to go in the Les paul. I am not sure if the nailbomb magnet is alnico or ceramic. BUT - I would like to have the cold sweat in the bridge and the nailbomb in the neck. Would I also have to have the magnets switched?
Also, is it easy enough to get silver (Nickel?) humbucker covers as these are just the black open coil covers?
« Last Edit: April 18, 2012, 01:29:33 PM by Elessar [Sly] »
Re: Help needed switching pickups
« Reply #1 on: April 18, 2012, 02:36:15 PM »
The Cold Sweat neck has an Alnico magnet and works well in the bridge. However, I would not put the Nailbomb bridge pickup (regardless of whether its an A-Bomb or a C-Bomb) in the neck position of any guitar. It will be too loud, too bassy and not balance well with the bridge pickup, especially with one that is only vintage level output. If you want to move the pickups to another guitar I recommend to use them in the designated positions.
Are you asking whether the cover will fit the pickup? If the pickup has open coils and no cover the cover should fit without any problems. If the pickup already has a cover (BKP offers black covers, too) then this cover must be removed before a different cover can be fitted.
« Reply #2 on: April 18, 2012, 07:20:13 PM »
Listen to Stephan, don't switch them.
  • Random Solution
« Reply #3 on: April 18, 2012, 07:27:04 PM »
Agreed, it wouldn't be a good idea. BKP designate them 'neck' and 'bridge' for a reason.
