Author Topic: Swapping Emeralds For Riff Raff/Mule In an Edwards LP  (Read 9945 times)
Rubblebrother
« on: April 24, 2012, 07:51:12 PM »
Hi, People, I am at the moment just wondering what difference I would get if I swapped out my Emeralds For a Riff Raff Bridge and a Mule neck in My Edwards LP, I really like the emeralds but I am very curious, how much more of an open tone would I get and Brightness from the RR/ Mule combination? I play Mainly Classic Rock and Blues. Thanks  :D
Re: Swapping Emeralds For Riff Raff/Mule In an Edwards LP
« Reply #1 on: April 24, 2012, 08:14:08 PM »
I think you'll find you'd have a brighter, sharper tone from both pickups - especially the RR  :)
TheyCallMeVolume
« Reply #2 on: April 24, 2012, 09:10:06 PM »
Couldn't agree more!
« Reply #3 on: April 25, 2012, 12:22:35 AM »
Nothing to add to previous contributions. Why not a Mule-set? The bridge is great for classick rock too.
« Reply #4 on: April 25, 2012, 02:27:02 AM »
my favorite set after trying a dozen different pickups (mostly BKP) in my les paul custom
« Last Edit: April 25, 2012, 02:29:17 AM by Eric Hellstyle »
Rubblebrother
« Reply #5 on: April 25, 2012, 05:44:32 AM »
Thanks guys, OK what are the pros and cons of a riff raff / Mule set and All Mule set  :D
« Reply #6 on: April 25, 2012, 08:45:36 AM »
Riff Raff/Mule will have a sharper bridge and a stronger contrast between the bridge and neck positions. These are pros or cons depending on the way you look at it.
« Reply #7 on: April 25, 2012, 09:06:35 AM »
Yep - it depends how much contrast you like between bridge and neck  :)
« Reply #8 on: April 25, 2012, 10:51:01 AM »
Is there not much contrast between the Emerald bridge and neck, then?
(I really should get round to fitting mine, shouldn't I....?  :oops:  :roll: :wink: )
« Reply #9 on: April 25, 2012, 10:55:32 AM »
What I mean is that the same wire/magnet/wind as a set usually gives a closer tone match than two different models.
In this case:
Mule = Alnico IV = slightly less winds
Riff Raff = Alnico V = slightly more winds
« Reply #10 on: April 25, 2012, 11:08:32 AM »
Got you.   :)
But the Emerald set is also AV bridge, AIV neck (both with 43 AWG wire?) so I'm assuming there's a reasonable amount of bright vs warm contrast?
« Reply #11 on: April 25, 2012, 11:18:54 AM »
I can't really remember to be honest!  :oops:  I'm guessing the winds will be closer matched...
« Reply #12 on: April 25, 2012, 11:20:19 AM »
The Emerald carries you more on leads, but the RR will give more crunch on the rhythm.
I like the RR but it's a tad more fight involved than with the Emmy, as the latter compresses nicely on the treble strings.
Rubblebrother
« Reply #13 on: April 25, 2012, 02:37:03 PM »
Thanks again for the info. I guess I want to get a more open tone but still have some bite, hence the riff raff, the emerald neck is really good but I find the bridge lacks something I want in my tone, its hard to describe, maybe its not pick sensitive enough( though I was sure it would be)  or im looking for a bit more brightness?
« Reply #14 on: April 25, 2012, 02:37:48 PM »
Oh well, I'll find out.... eventually.  :lol:
If I end up with the Cold Sweat set in one PRS and the Emeralds in another, it'll be interesting to compare and contrast.
