Looking for the right BK.
Started by KevinMarchesini, May 08, 2012, 05:07:40 AM
KevinMarchesini
The guitars where possibly these pu's would being installed are Ibanez.
1.- Mahogany body, maple neck, rosewood fingerboard, bolt on.
2.- Mahogany body, maple neck, rosewood fingerboard, neck trough.
3.- Basswood body, maple neck, rosewood fingerboard, bolt on.
I'm looking for high output, punch, gutural-like, with the EQ like the Dimarzio Super 3 (5 treble, 8 mid, 6,5), not to bassy and with rounded (non harsh) treble.
Quote from: KevinMarchesini on May 08, 2012, 05:07:40 AM
Check out the Holydiver. It would not have as much output as the Super 3 but fit the tonal description.
KevinMarchesini
#2
And what about the Crawler? I would like to see a comparison between the Crawler and Holy Diver.
itamar101
Quote from: KevinMarchesini on May 08, 2012, 09:23:18 AM
A crawler would be much too dark for those woods.
I'd also go for the holy diver.
TheyCallMeVolume
The Crawler is quite mellow on the bassside. The HD sounds more modern and tighter. HD gets my vote.
KevinMarchesini
I want to equip a gibson les paul replica (Hondo II). Which pickup would suit best this guitar? I think Warpig would be too much bass, dark or muddy.
TheyCallMeVolume
Well it matters what you want it to do, but THE LP pickup is the Rebel Yell.
Holydiver in the Ibanez guitars but I'm not sure I'd bother on a Hondo II.
itamar101
#9
Quote from: allstar100595 on May 09, 2012, 06:52:43 PM
Don't be sure about that. Most BKPs work extremely well in LPs and TBH if you want "the LP pickup" you should get The Mule.
It all depends on what you want to play. My Holy Diver sounds absolutely amazing in my LP, as does my Emerald and as do Mules and Riff Raffs and I'm sure that the Rebel Yell sounds absolutely amazing too.
Saying that, I think that either the Holy Divers or the Rebel Yells will fit TS best. As the others said, I think that in this case, the Holy Diver just edges it.
The RY and the HD are made for pretty much the same types of music. At that point it all depends on the characteristics that you want your pickups to have. They'll play exactly the same range of music in the same guitar equally as well.
Holy Diver -
Fluid, smooth, yet aggressive.
Thick and great cleans and coil-split sounds.
Balanced EQ with a slight mid boost but a nice tight and responsive bass and smooth yet very evident highs.
Lots of "Oopmh/Punch".
Rebel Yell -
Slightly less fluid and a bit more aggressive and bitey.
Also quite thick but not as thick. Very good cleans too, i haven't heard them coil tapped.
A bit brighter than the Holy Diver but not as much as brought to believe. Certainly not harsh as long as you get the pickup height and amp setting right.
Similarly punchy.
A bit tighter than the HD but the HD can easily match that with the use of a TubeScreamer. THe HD is still relatively tight.
They are both great at classic rock, hard rock, 80s metal (both are especially good at this), progressive rock and modern metal (high gain amp and tubescreamer needed for this no matter what pickups you have, Lol).
TS just need to choose what characteristics he wants.
Just like most others here though, I'll recommend him the Holy Diver in this case.
Edit: I got confused. If TS is already getting the Holy Diver for his Ibanez then I WOULD get the RY for the LP for added versatility.
KevinMarchesini
Thanks itamar101.
I play mostly metal and I'm looking for that sound you described very well, the "Oopmh" that gutural-like sound. I want to have noticeable punch and output,  a very fat full sound with predominant mid frequencies, tight bass and rounded highs. I also like to use lower tuning like D standard or drop C, sometimes lower than that.
What I'm describing  better? The Warpig or the HD?
How would sound the Warpig on a Ibanez 550 (basswood body, maple neck and fretboard)? I think it would be right cause for me basswood is a bit flat sound, I mean it reflects very well the characteristics of the pickup.
What would be the difference between the Warpig with Alnico V and the Ceramic magnet?
the alnico nailbomb is a bit hotter and punchier than the holy diver
it feels slightly hotter than the alnico warpig as well, cause it's more focused sounding instead of smooth and compressed
the mids aren't bumpy like the holy diver, though
it's still a pretty throaty pickup
KevinMarchesini
Thanks for the extra info but that doesn't answer my questions.   :lol:
In your first post in this thread you describe the Diver.
KevinMarchesini
I know and that question was answered. Now I wanna know the others. :D :D
