Output level Aftermath/Painkiller/Warpig
Started by LiveWire, May 08, 2012, 10:49:55 PM
LiveWire
Hi folks, I'm new here. Just got tipped to enter this forum, found some good info, though I'm still trying to figure something out which I hope you guys can help me with.
With my band I play thrash metal so I need a fair amount of overdrive. No problem you'd say, but I got myself in a tight situation here since I use a plexi clone and want to plug straight into the amp, no pedals, no active pickups.
Currently I'm using a Dimarzio X2N and that works extremely well. Only trouble is, the guitar I have has much more to offer acoustically then the pickup picks up, and I hope a BKP can do that.
From what I managed to find out the Aftermath/Painkiller/Warpig are the ones with the highest output. But how would they be ranked output-wise, and can anyone confirm if they deliver as much output as the X2N?
Thanks!
the x2n is hotter than any BKP
tonewise, the painkiller is probably the closest model, but it's not oversaturated like the x2n
hard to picture a non-hotrodded plexi doing thrash metal without any kind of booster, though
dark order flying V
Quote from: LiveWire on May 08, 2012, 10:49:55 PM
Thanks!
Hey dude! I play in the Thrash Metal band DARK ORDER. I Can help!!!. What type of guitar is that you play??? Is is bolt on? Neck Thru? Set neck? Woods??? Tremolo or hardtail bridge??? Pitch you tune to and whats yor favourite guitarists sound????.
I can already tell you that the Aftermath is not a pick up for straight into the amp Thrash Metal. It will be either three BKP pickups... the Ceramic Nailbomb, the PainKiller or Ceramic Warpig.
Thrash Metal is my blood
Alex
I think no pickup will match the X2N - it's supposed to be one of the hottest pickups out there; the only ones I could think of that might reach that silly output (yes, silly IMO) could be the Seymour Duncan Blackouts.
Madsakre
I would either go for a painkiller OR my new found love. The EMG Het set. Best distorted tone i've ever heard.
Cattlepress
LiveWire
@ Eric & Alex: Thanks, that seems clear. It's true I'm limiting myself here with a need of so much output. The thing is, I love playing straight into the amp and would hate it if I had to depend on a pedal. Have thought of building one into the guitar, but that's the same story then.
Attached a sound sample so you can hear the overdrive-level, this was with my old G12T-75 speakers though, did a major upgrade a while ago. Also, I have two X2Ns of which one delivers more output then the other, this is with the waeker one.
@ Dark Order: I'll definitely check out your band (if you have stuff online). Nice to have another thrash head gear hound around. That guitar is a Jackson Pro (basswood body, quartersawn bolt-on maple neck with ebony fretboard and Floyd, tuned in E). Like a clear/bright lead tone. I'm leaning toward the Painkiller (so thanks for confirming that Madsakre) but the Warpig seems more dangerous..
Madsakre
The Painkiller is way more aggressive than the warpig. The warpigs are big and fluffy. The painkiller is more like a pitbull
Cattlepress
TheyCallMeVolume
I think the Painkiller would be best, but I need to say, there are many GREAT mods you can do to that amp that would help a lot in getting your tone. I would recommend looking into a few of those to get your tone somewhere special.
TheyCallMeVolume
And like I've said before elsewhere on the forum, your favorite guitar tones are more likely than not driven by low-output pickups and very high gain amps. The tone you're imagining in your head might be something very different with just a pickup and a Plexi amp.
dark order flying V
Quote from: LiveWire on May 09, 2012, 10:15:21 PM
For a guitar like yours, the Painkiller is Way way to bright and middy. I strongly suggest either a Ceramic Warpig OR a Alnico Nailbomb. You need good mids for Thrash, and in a strat type guitar like yours, with basswood and ebony frettboard, where bass wood is NOT a warm sounding wood, nor it is great with low mids, the Ceramic Warpig with slam the front end of your amp for that palm muted chunck, and or the Alnico Nailbomb has this real cool 'SD SH4 JB ala Anthrax palm muted chunk + mibs' just minus the fuzz of the JB
LiveWire
Quote from: allstar100595 on May 10, 2012, 12:10:13 AM
I modded it quite a bit, NOS parts and tried a range of different resistors and caps on relevant spots, dropped the voltage on the tubes. There's not a problem with the tone I'm getting. It's just that the pickup doesn't reveal everything the guitar has to offer.
@ Dark Order: I have several basswood bodied guitars, and this one actually has a pretty strong bass. The staccato palm mutes are the first to go when you're not reaching enough overdrive so that's a good thing to concentrate on. Fistful Of Metal is one of my all time favourites, and next month they're coming to town 8) The palm mutes on that album are aggressive, very sharp and bright, excellent. Though the overall guitar sound is pretty flat and not something to strive after.
did you wire the gain stages in series (cascading)?
the miracle man is known for working pretty well in basswood and maple
LiveWire
Hadn't heard about that yet, thanks for the heads up, I'm looking into it. There's a lot of ways to do a cascade I see, this will take some studying.
Quote from: dark order flying V on May 09, 2012, 06:13:19 AM
.....huh?
I find this confusing. The AM is just as capable of thrash right into an amp as those other 3. As is the MM and cold sweat. Even the crawler, in fact. And others, by reputation and from clips I've heard but I should just keep my comments to pickups I know, really.
Livewire: you should probably get a miracle man. You wont get quite as sharp an output drop as with the PK, AM or CS which should make the move from the X2N a bit easier, and its very responsive to different guitars for such a hot pickup.
DoomBuggi
#14
Quote from: dark order flying V on May 10, 2012, 01:17:54 AM
For a guitar like yours, the Painkiller is Way way to bright and middy..... where bass wood is NOT a warm sounding wood, nor it is great with low mids...
I disagree with this quote. I have found Basswood to be warm, and definitely not lacking in Mids. I also disagree that the Painkiller would be too bright for the wood composition in question.
http://www.warmoth.com/Guitar/Bodies/Options/BodyWoodOptions.aspx
The Painkiller is excellent for thrash in my opinion.  The Aftermath can do it as well.  The Painkiller is going to have more bite though.
