November 20, 2026, 01:22:57 AM
Main Menu
Main Menu
Home
Search
Bare Knuckle Pickups Forum
Forum Ringside
Tech
want to change amp from 6v6 to el84, having to simplify
Started by sgmypod, May 09, 2012, 11:07:45 PM
Previous topic
Next topic
Print
Go Down
Pages
1
User actions
Welterweight
Truly bad since 1972
Logged
Last Edit
: June 03, 2012, 12:03:12 PM by sgmypod
aimed at amp blokes, would like valve, bases etc everything to do, is it possible obviously will have 6v6 or el84 in but have the two valve bases permanently connected. have provided schematic and drawing
jpfamps
Lightweight
Logged
Re: want to change amp from 6v6 to el84(leaving orig valve base in so can swap back)
#1
May 09, 2012, 11:20:02 PM
We built a single ended amp with switchable EL84/ 6V6.
I think we used a DPDT switch to simultaneously lift the cathode on the unused valve and switch the filament supply off. This was with both valves connected to the OT.
By doing this we avoided having the unused valve on and wearing out, and avoided any switching of high voltages.
I could probably generate a schematic.
Welterweight
Logged
#2
May 10, 2012, 07:37:26 PM
cool how much schematic and parts
jpfamps
Lightweight
Logged
#3
May 11, 2012, 05:19:25 PM
I've composed a schematic and will try to remember to bring it into the workshop where I have internet access.
Middleweight
Logged
#4
May 11, 2012, 06:43:50 PM
It'd be cheaper to buy an Epi Valve Junior, strip out the guts and wire it PTP.
The Harley Benton ones are the same, but slightly cheaper.
Welterweight
Logged
#5
May 11, 2012, 07:57:43 PM
Would have thought that would be more, would'nt I need to buy new trannies for them
jpfamps
Lightweight
Logged
#6
May 12, 2012, 11:49:12 AM
Here's the schematic.
The resistors marked in blue probably aren't needed, and I wouldn't include them.
I've not included the screen grid circuit and guestimated the cathode resistor values etc.
Welterweight
Logged
#7
May 13, 2012, 12:12:48 AM
Thanks frank, could you supply bits
Welterweight
Logged
#8
June 03, 2012, 11:53:40 AM
frank i have run out of, space and skill. so am going to just swap out 6v6 for the el84 (obviously swapping pins)
so with bits you sent need swapping on the original schematic
6v6 C9 22uf 25v (el84 100uf)
6v6 R9 470R 2w (el84 150ohm)
6v6 R8 10k (el84 1k)
6v6 R10 470r (el84 10k)
am i correct or miles out (as say will connect pins correctly on top of this)
Welterweight
Logged
Re: want to change amp from 6v6 to el84, having to simplify
#9
June 06, 2012, 12:14:04 PM
Was slightly out, thanks frank
Print
Go Up
Pages
1
User actions
Forum Ringside
Tech
User actions
Print
