Treble Bypass Mod
Started by Fixxxer_1988, May 28, 2012, 10:13:25 AM
Fixxxer_1988
Does anyone have any experience with fitting a treble by pass mod into a guitar? I have PRS which was fitted with one when it was stock but that was so long ago I don't remember if it was really that different. I was thinking of fitting a 180pf accross the in and out of the volume.
Please share any other values recommendation or different ways of going about the mod.
I am fittig a black dog in the bridge and a mule in the neck of it make any difference.
Cheers guys
PRS Custom 22 with Black Dog Set
Fulltone Clyde Wah
Cornford Roadhouse 30
Pete24v
If your a volume all the way up all night player then it's not much use.
i use these on all my guitars http://www.ebay.co.uk/itm/TREBLE-BLEED-SILVER-MICA-0-001uF-150k-1-RESISTOR-/200758865688?pt=UK_Guitar_Accessories&hash=item2ebe292f18
My volume is always 5-8 and then 10 when i need a little push.
Fixxxer_1988
I use the volume control to control my whole sound, from cleans to crunch to full on leads. I set and forget the amp and never use footswitches. it is pretty old fashioned but it works for me. Just wanted something that will let me have the same/similar EQ from 1 on the volume to 10. I have a tone to control the darkness I don't want the volume to do the same!
Fulltone Clyde Wah
I'm slowly converting all my guitars to use '50s' spec wiring and decent capacitors. I find this avoids the needs for a treble bypass capacitor.
Fixxxer_1988
Quote from: gwEm on May 28, 2012, 01:08:37 PM
What does the 50s spec entail?
Fulltone Clyde Wah
Quote from: Fixxxer_1988 on May 28, 2012, 01:12:59 PM
its just moving some wires around. works a treat. loads about it online:
http://ashbass.com/AshBassGuitar/Gibson50s.html
for example
Fixxxer_1988
Awesome, thanks for the link. I think I will get on and do this, this week :)
Fulltone Clyde Wah
Miracle Man
180pf is the original PRS value. I've tried 50s wiring, 50pf to 1000pf and almost everything in between. In the end I installed BKP/CTS 550k pots with regular (not 50s) wiring and I love it. There is some treble loss but it sounds really sweet without getting muddy. I highly recomend it.
The next best thing (IMHO) is regular wiring with a Suhr-style bypass: 150k/680pf in parallel. You get a different taper that way, much more linear but the clarity is great without losing brightness. If you really want a "guitar mounted gain control" this is the way to go.
I used 50s wiring on all my guitars for years, but have gradually went back to modern Gibson wiring with 180pF bright caps, it just sounds meatier.
