Author Topic: seemingly impossible to resolve issues with Nailbomb  (Read 10492 times)
ZymoticPlague
« on: May 30, 2012, 11:25:32 AM »
Well, I should start off by requesting no replies that completely negate the information provided within my post. PLEASE, don't suggest a "remedy" after I've clearly explained that it has already been tried, tried again and still did not solve the issue.  Not to be crass, but I've talked myself blue in the face and typed my fingers ragged trying to remedy this and don't want to be going in perpetual circles forever with this with anyone.
This is the issue: I have a custom made single pickup guitar. Glued-in neck thru. Rock maple neck with an ebony fretboard set into a myrtle body with a burled maple top. 7 string floating tremolo with a Tremel-No. 36 frets, hence only one pickup. I ordered the alnico bridge Nailbomb 7 covered because Tim recommended it as the best fit for having a lot of variety in one pickup, as I would need it because I would be playing distorted/ clean & rhythm/ lead with the one pickup and trying to cover a lot of territory tonally and by genre, etc. A multi-purpose guitar, this is.
Now, the pickup sounds just fine clean, both full hum and coil tapped. Just rolling the tone knob off and on between tapped and hb is like toggling between pickup combos with a single coil and humbucked guitar. Sounds great. Distorted is an entirely different story though.
I cannot seem to rid of a buzzing/humming sound that I get with gain and I don't use an obscene amount of gain neither. EVEN if I switch between a multi fx module like a Korg Pandora (and using full noisegate) through a little practice amp, or running Amplitube Metal in Nuendo3 (obsolescent, I know!) going through a Digidesign MBox2 (using noisegate. *Also, this is the worst sounding of the 3 setups I use and there's no amp in this equation), or simple analog pedals through an old school tube amp (Boss NS-2 Noise Suppressor can't even get rid of the noise), I have the same problem more or less. I've tried different outlets in different rooms in the house. I tried different guitar cables in different orders with the 3 different setups. I have 2 other guitars, one with slightly hot passive HSS set and another with 2 active EMG. Neither have ANY noise problems whatsoever through all 3 aforementioned "rigs" that were tested.
I had the luthier that made the guitar AND installed the pickup check it out at least 3 times now. Everything comes back clear as far as there not being an issue with the grounding, as there is a test tone to confirm continuity EVERYWHERE including the pickup cover, etc etc etc. The solder joints all checked out, as the wiring, for he has installed a BK in many a guitar, and all without fault to any degree like this, save one pickup which he ultimately DID have to send back (a Black Dog) for being faulty, which is where I think this may just have to go towards as well.
I also bought a multimeter and tested at home just so I knew what to look at/for and also had checked at a well known guitar shop here for continuity, proper wiring, etc. Checks out fine.
Its metal components DO cancel out A PARTICULAR noise, (though not the droning, monotonous noise I have been speaking of) of which sounds like that of a grounding issue and is apparent when NOT touching the strings or metal components, but I have been told is just sometimes apparently inherent of hotter passive pickups(?)
The hum/buzz I originally spoke of, though, is present regardless. In fact,  it actually sounds like a guitar cable unplugged from the guitar and on the floor, but LOUDER and more pronounced when plugged in. As mentioned, even with noise gates/suppressors in use, it is heard WHEN playing or sustaining notes.
Now...since this is NOT, I repeat, NOT a ground issue as should it be apparent thus far...nor any of the other problems I incorrectly diagnosed myself so far, what could it possibly be besides a faulty pickup?!?
OHHHH...and I should mention that the sound is literally 2x louder and worse sounding when coil tapped.
Oh yeah...and the volume knob makes scratching noises when rolled off and on, BUT...BUT only when the strings are not being touched. It is NOT the volume pot, which has been replaced 2x just in case and plenty of contact cleaner and compressed air has been blown in the current one to fix the problem IF that was the problem. The major red flag here being that it ONLY scratches when NOT touching the strings and rolling the volume up and down, which means goodbye volume swells and slow fade outs without having am/fm radio station changing sounds in the mix.
Vintage Metal
Re: seemingly impossible to resolve issues with Nailbomb
« Reply #1 on: May 30, 2012, 12:16:45 PM »
Did you have the guitar made with the Nailbombs in, or did you have something like active pickups in it before hand?
I know you said you didn't ask for a remedy, but I really have to ask this, and if I'm right, it will take a matter of minutes to sort out and won't cost you a thing besides your time:
One thing to do is to check that the bridge (trem or hardtail) is grounded as this is a very common problem with the problems you seem to have. Most people who have this problem are players who have switch from active to passive pickups and have forgotten to ground their bridge. If you didn't have active, it's still worth having a look.
Like I said, sorry to advise a remedy since you said you've checked grounding, but bridge grounding is a very common overlooked aspect of grounding. In fact many people wouldn't even think twice about it. Sorry to hear about the problem though, it's a very annoying pain :(
If everything is fine though, message BKP and explain the problem, I'm sure they'll be happy to tae a look at the pickup and offer to fix/replace it.
« Last Edit: May 30, 2012, 12:21:08 PM by Vintage Metal »
« Reply #2 on: May 30, 2012, 12:21:00 PM »
And you're saying none of this happens when you're running the same guitar through a clean set-up? Hmmm... I'm at a loss then (and my gut feeling is it's not the grounded bridge thing that Vintage Metal asks about - although I think it's right to consider/recheck it)
I'd recommend emailing this little lot straight to BKP and ask what they think - they'll want to make you happy.
Hope you get it sorted soon.
Welcome to the forum, btw :D
Miracle Man
« Reply #3 on: May 30, 2012, 12:44:26 PM »
If you're handy with a soldering iron or know someone who is, maybe you should do a quick swap and try the Nailbomb in one of your other guitars. If the problem persists with a different guitar, then it's probably the pickup.
« Reply #4 on: May 30, 2012, 12:52:26 PM »
that might be it- the tremol-no is grounded by a screw, not soldered, and it tends to come out.
Vintage Metal
« Reply #5 on: May 30, 2012, 01:02:29 PM »
Don't you solder it to the back of one of your pots though? I've got a small wire coming out of the side of the back cavity in my Les Paul, which is soldered to the back of my neck vol pot. Well I'm pretty sure this is my bridges ground wire haha.
ZymoticPlague
« Reply #6 on: May 30, 2012, 01:16:39 PM »
thanks to all you have replied so far! I really do value any input i can get; i was just overtly frustrated and must have expressed that well!  :lol:
to answer the 1st reply: yes, I did have a *****y sounding 707 in there. The pots, jack, etc were replaced to meet the right resistance and there was a hole drilled (pained to see!) from the cavity and to the meet at the bridge, where the Tremel-no secures the ground wire with an allen wrench fitted screw (i figure thats the only purpose that screw could possibly serve) and the other end soldered to the volume pot.
I have contacted BK and have terrorized Mr. Mills quite enough now I think! Between the guru himself, the luthier of my guitar and even 3rd party opinion, no one has come up with a solution that hasn't been tested that would probably solve this. I figured it was time to branch out!
the vol. scratching issue has duped too due to the contradiction of how it does it, being the atypical way that most would encounter. Help!!!
« Reply #7 on: May 30, 2012, 01:48:30 PM »
This sounds very odd.  Is the volume knob metal or plastic?
I think Troy's suggestion of trying the Nailbomb in another guitar (and/or another passive pickup in this guitar) is a good one, although it is a pain in the arse doing pickup swaps.
BigB
  • Let's rock !
« Reply #8 on: May 30, 2012, 08:32:19 PM »
Just a couple things that came to my mind:
1/ there's much with ground issues more than just proper ground wiring on the guitar itself - "correct" grounding is about as common as nessie, be sure that whatever you do and however good you are, you WILL have ground issues.
2/ the "scratchy pot" syndrom (once you rule out defective pots) is most often seen in tube amps, and usually comes from DC leaking thru a faulty cap.
It obviously won't help much, but I thought I'd share this anyway, just in case it could help one way or another. Else, well, just what PillyQ said : swap your NB with the bucker in your HSS guitar (and no Phil, it's not a PITA, just plain boring).
Toe-Knee
    • DIY Audio
« Reply #9 on: May 30, 2012, 08:47:29 PM »
This may sound weird. But what strings do you have on the guitar?
I have found that some strings are non conductive/not as conductive as they should be.
Also the tremelno grounding point is useless. I had my ground attached there and still got some buzz althought not as bad as you are describing. I replaced the wire and attached it directly to the bridge and it instantly cured it.
http://WWW.BACKLINE.TK
Non Biased Guitar Forum
http://fret.boards.net
ZymoticPlague
« Reply #10 on: May 31, 2012, 06:07:18 AM »
real quick: i can't put the NB in another guitar because it is for a 7 string guitar and i only have the one 7 string! it wouldn't fit even if i wanted it to, and i'd hate to thrash either one of these guitars here and have the pickup all hanging out or whatever to see if it does this or that. i think maybe it is the way it is attached to the tremol-no. i guess i can see about soldering it to the bridge.
as for the vol. knob, it is chrome finish metal. unfortunately, it's probably not my MusicanMan (amp) because it does it when i play through my computer (and actually is the worst sounding through my computer TBH).
if it is a ground issue with the tremol-no, wouldn't it not produce the test tone?
Toe-Knee
    • DIY Audio
« Reply #11 on: May 31, 2012, 06:35:26 AM »
By test tone i presume you mean the continuity beep? It did on mine but the ground wasnt the best connection. It was far better after i moved it. But also my issues weren't half as severe as yours sound
ZymoticPlague
« Reply #12 on: May 31, 2012, 08:44:54 AM »
sorry, yes the continuity sound from the multimeter. I think that might just be it. as for the volume knob...not sure. seems to do it for me more so than in the hands of others. possibly some weird charge my body puts off... :x
« Reply #13 on: May 31, 2012, 08:45:35 AM »
The reason I asked the question about the volume knob being metal or plastic - you said the volume knob makes scratching noises when rolled off and on, but only when the strings aren't being touched.
So when you are touching the strings, there's effective grounding and touching the volume knob makes no difference.  When you're not touching the strings, there's noise when you touch a metal part - the volume knob.  That must be some kind of grounding issue.
I don't know what's wrong here, but I think it is grounding, one way or another.  And I doubt it's the pickup that's at fault.
ZymoticPlague
« Reply #14 on: May 31, 2012, 09:59:09 AM »
another little anomaly: after resecuring the ground wire to the tremol-no, i noticed there are scratchy noises (like with the volume) when a metal item like an allen wrench is even just lightly rubbed across any metal.  is there a grey area with proper grounding? ugh! this sucks! i can't WAIT to get this over with! Sincere thanks to all that have replied so far!
I hope I don't have this issue with the Holy Diver that I had ordered right after this one! doh!  :roll:
