Author Topic: Painkiller too much bass  (Read 2151 times)
Dillinger
« on: May 30, 2012, 05:53:57 PM »
Hi ,
I have a BKP painkiller installed in my Heritage H-150 (les Paul type guitar , mahagony body and neck , flame maple top & rosewood fretboard) but it's really bassy and not tight and it doesn't feel like it should sound like that , I checked the wiring (2 vol 2 tone 3 way switch) , color code , resistance ( reads 17k although the site mentions 15k) the pots are all CTS 500K and caps are 22nf , I have also wired the humbucker directly to the jack and actually there's no diffrence with the low end , adjusting the humbuckers height doesn't seem to reduce the bass either.
I'm really confused now I don't know whether the humbucker is defected or just doesn't suit the guitar ( although I heard a lot that painkillers sound great with mahagony and les pauls) besides that I have no clue what can cause it.
Would like to hear your suggestions and opinions.
Thanks.
Re: Painkiller too much bass
« Reply #1 on: May 31, 2012, 02:09:14 AM »
sounds like you have it too close to the strings
« Reply #2 on: May 31, 2012, 06:03:54 PM »
What pickup was in your guitar before and what amp are you using? It could be that the Painkiller has more output overall and distorts the amp more than before.
« Reply #3 on: May 31, 2012, 06:15:01 PM »
Based on your description the pickup seems to be OK and the symptom you describe does not sound like a wiring error. 17k vs. 15k is not a drastic difference and can be the result of differently calibrated meters or different temperatures (resistance increases with higher temperature).
It could be that guitar and pickup are not a good match but there is too little information for such a conclusion. Try to adjust the pickup height and reduce gain/bass in the amp.
TheyCallMeVolume
« Reply #4 on: May 31, 2012, 08:20:07 PM »
I would say string height comes to mind first.
