Author Topic: Jazz guitars - how to get that piano tone ?  (Read 26887 times)
Fourth Feline
  • Ten minutes, then you really should practice ...
Re: Jazz guitars - how to get that piano tone ?
« Reply #30 on: June 08, 2012, 04:33:53 PM »
Thanks for all the contributions above, which have definitely influenced my choice.
The die is now cast: Peerless Sunset with TI Bebop 12s.
Going to let it settle in, but expect to replace the neck pickup ('57 Classic) with a Manhattan down the line.
Will keep you posted.
I genuinely think you would be delighted with a Manhattan in the neck postition .   8)
When you do get one , try a pickup height of 3mm between the top of the pole pieces and the underside of the strings,  when the strings are fretted at the last fret.
The usual 'good to go' setting for the low to medium BKP pickups is  2 - 2.5 mm  ;  and whilst  this is also true for the luscious Manhattans and sweet Stormy Mondays,  I have found that a specific bias towards 'Piano' sounds and chord melody in general -  often benefits from a touch more 'air' in the sound.
One of the reason I like my BKPs , is the fact that they are delightfully height sensitive - and give you a classic sound / platform from which you can then 'dial in' a number of subtle variations.
The last bit of minutae, is the use of a D'Andrea 'Pro-plec' for your test pick .   I found them to give me the best ever  sweet , round and yet focused '50s Jazz'  sound.   Fender clears in a medium are very open sounding, yet still avoid that annoying 'scratchy' sound.  However, if you want to hear the note - and nothing but the note, get your hands on a D'andrea pro plec or two, in your favourite shape.
happy experimenting !  :)
« Last Edit: June 08, 2012, 04:44:04 PM by Fourth Feline »
BKP Manhattans, Stormy Mondays,  Mules , Missisippi Queens , ( Alnico) Warpigs - and VHII Bridge.
timski
« Reply #31 on: June 13, 2012, 12:01:35 AM »
Hopefully my experience might be of help:
I started playing jazz on a Gibson ES135 - similar to the 137. It was OK but despite swapping pups and trying various strings and amps I could never get a convincing jazz tone, although it was quite a versatile guitar.
After many years I moved on to a Godin Kingpin and swapped the stock pup for what would now be called a Half Note. I was really into Charlie Christian and Grant Green at the time and the guitar was great for that, but not terribly suitable for more smooth, fluid styles.
I then went for a Peerless Sunset (thinline but hollowbody, floating bridge, etc).
The Sunset is perfect and I haven't even upgraded the stock Epiphone humbuckers.
I hear people mention the 'piano tone' a lot in jazz guitar circles. I've never really understood what they meant! I am also a pianist and can hear little similarity, except on occasion when listening to someone like Jim Hall who can have a very thumpy sort of tone.
Hope this helps!
« Last Edit: June 17, 2012, 04:47:19 PM by timski »
timski
« Reply #32 on: June 13, 2012, 12:09:58 AM »
Oops didn't see page 2&3 of this thread!
Great choice by the way.
I have my Sunset strung with TI Swing flats, 13 gauge. When I get the cash will install some unpotted Alnico 2 Stormy Mondays.
Fourth Feline
« Reply #33 on: June 13, 2012, 01:16:27 PM »
After many years I moved on to a Godin Kingpin and swapped the stock pup for what would now be called a Bluenote. I was really into Charlie Christian and Grant Green at the time and the guitar was great for that, but not terribly suitable for more smooth, fluid styles.
Hope this helps!
It was great to hear of your experiences with the hardware - and thoughts on 'Piano tone'.  We don't get that much banter about heavily strung archtops around these parts !  I am surmising that what many call  'piano tone' is just  a certain  clarity of note defininition and the presence of subtle dynamics , combined with a sustain that is felt through the body of the instrument.
I appreciate that ( in theory ) sustain is sometimes thought undesirable in Jazz guitar circles, as you want the note to be sweet but die young, so the next note / notes in a chord sequence  can be heard in their own right.  Given that subtle left hand damping and choice of pick can 'control' that sustain, it becomes desirable to have a clear ringing sustain, for the ' Big finish' chords - and pedal notes e.t.c   Those of us that never played the piano, but heard other people do so, tend to carry with us a memory of this cavernous resonance and sustain that seems to keep going when you leave the room .  I suppose ( for me ) it is a sense of the note being pianesque - as it is struck with a jaunty 'bounce' - and therefore all the harmonics can swell up around the fundamental tone.  So I suppose it is essentialy about producing 'the tone in your head' with the unplugged guitar - then choosing / setting the amp and cables to make the guitar sound physically bigger, as opposed to merely louder. To magnify the volume, but get out of the way of the tone. The Phil Jones AAD Cub comes to mind in that respect.
I like the whole T.I. flatwound sound ( currently using 12s for ease of movement , and increased subtlety in the dynamics ) - but looking to return to 13s when the fretting hand gets more practiced .   I read in a rare Q&A session on a Japanese fan site for Joe Pass, that in later years, he used the T.I. Swing in 13 - and knew the guy behind the company.  I like the fact that 13s just don't move sideways even if you grab a chord clumsily , and of course that wonderful firm feeling under the fingers in general.
As one who is gradually building an understanding and repetoire for solo, duo or trio work,  the idea of string noise is undesirable ( as there will be nothing around me 'blasting ' loud enough to drown it out )   so flatwounds are my weapon of choice. They do of course tend to sound less '3D' that the corresponding Thomastik or Newtone Roundwounds, but rich and lush, instead of rich and 'springy'.
The idea of unpotted Stormy Mondays sounds brilliant ! I use the potted version in my modded Ibanez AF75 - and it gives a sound ( even in this relatively cheap guitar ) that I could happily use for many years to come.  A close call between the Manhattans and these, but the Manhattans I have are Gold plated, whilst the Ibby has Chrome fittings.
Today's 'Google' time must include another look at the Peerless Sunset, not for credit card battering, but for the appreciation of a lovely thing .  8)
Cheers !
« Last Edit: June 13, 2012, 01:22:45 PM by Fourth Feline »
FredD
« Reply #34 on: June 14, 2012, 08:15:11 PM »
What a relief to hear someone talking about proper music, rather than all this 'metal' nonsense.  8)
I was beginning to think that we were a 'lost tribe'  :)
Tomastik flat wound 13s for me, on my Artcore AS103.
Fourth Feline
« Reply #35 on: June 14, 2012, 10:23:42 PM »
Excellent !  :D
I can imagine that the lower tension / better balanced T.I. strings feel nice , even on a guitar  with a standard tailpiece.  :)   My assumption that the set back Lyre tailpiece reduces tension, might be purely psychological, or more realistically , it is probably to do with giving softer 'break angles' where the strings leave the bridge e.t.c.  The AS103 would have been my more obvious thinline, due to it having the same neck and build qualities as the ( pleasantly surprising ) AF75.
I tend to bang on about the pleasures of the chord melody style,  but for me, it's the joy ( after many years of Hacking  my way through  Blues / Soul / Rock'n'Roll styles ) - of finding something that really got me fascinated with the music itself - and a better understanding thereof.  I choose the guitar , but love a good song.  When I pick up a nice comfy guitar , with heavy flats on, It's natural to think of the guitar as my chosen tool for exploring the fascinating realm of what would perhaps usually be thought of as a pianist's repetoire.  That satisfaction of experimenting with chord voicings , and training both the ear and mind to be better at going through a melody on the stepping stones of sweet / emotive / elegant chords e.t.c   The greatest projected ambition, would be to work with/accompany a like minded, velvet voiced singer - ( or 'Comping' - as they say in our quaint corner of the woods   8)).
I also want to avoid doing what I did with the previous style(s) - and that is jumping ahead to the improvised single note stuff.  After a further year or two on chord melody ( with a progressive , but relatively modest  'daily dabble ' in visualising / hearing the chord scales and arpegios ) - the rest awaits ;    but I so enjoy the feel and completeness of the whole chord melody arena - that there are just so many beautiful songs that I want to inhabit first.  That lovely sound of velvet notes at low volumes - and getting excited about buying a piece of sheet music - to ( in my case ) slowly 'spell' through, and take it to the guitar like we used to take a vinyl record to the record player.   :D
« Last Edit: June 14, 2012, 10:40:28 PM by Fourth Feline »
Lezard
« Reply #36 on: June 15, 2012, 05:38:47 PM »
I second that, Nice to have you back FF, great to have another Hepcat knocking about.
Fourth Feline
« Reply #37 on: June 15, 2012, 07:54:48 PM »
Thanks, Lezard - most kind of you to say so.  :)
With respects to the purveyors of other styles, I think it is nice to ( collectively ) represent all the possibilities of BKP's range.  For me ,  the ' Hepcat friendly ' pickups  exemplify what most of us like about Tim's stuff ; the openess, the dynamics - and the way that all tastes and styles are catered for.   When Telerocker told us he was using his BKP Mules to cover the bases in a covers band doing " Everything from Joan Jet to Beyonce " it brought an appreciative smile - and of course reminded me that we have the whole range of players on here, 'cross pollinating' ideas and enthusiasms.    I would not really feel like spending any online  time on a Jazz specific forum,  prefering  the members, characteristics and general attitude of this one for banter - and the guitar itself for Jazz.
I really must plug into my Guitar Rig Mobile this weekend, and leave a few sound clips.  I have a lot of work yet to do on those tunes,  but meanwhile - hope to remind the casual browser , that the style / application is also covered by the BKP range - and you don't have to look elsewhere , if  your tastes are less mainstream .   :)
« Last Edit: June 15, 2012, 07:57:22 PM by Fourth Feline »
FredD
« Reply #38 on: June 15, 2012, 08:38:00 PM »
....well said FF and Lezard#... 8)
...."respects to the purveyors of other styles"....! :D
Lezard
« Reply #39 on: June 16, 2012, 02:34:27 AM »
Not Too much respect though.... :)
I'm on a few jazz forums myself, far too on topic.
djl
« Reply #40 on: June 16, 2012, 10:38:00 PM »
Hi I've come quite late to the discussion.
+1 on the TI strings - I have used the jazz bebop, George Bensons and the swings and have settled on the jazz swing sets for an awesome sound- 13s on a Gibson 175, 12s on a Hofner with a longer scale length.
The 175 has Stormy Monday in the neck (unpotted) and sounds really great. I have it set on the low side and play a lot of fingerstyle stuff.
One thing that no one's mentioned yet which I think contributes enormously to a good jazz tone is where to pick the string - whereas on "normal" guitars its often natural to pick between the pickups, for a decent jazz tone I find it best to pick more or less where the neck pickup is, for so called piano tones.
Fourth Feline
« Reply #41 on: June 17, 2012, 01:31:06 PM »
Nice to hear the weapons of choice ( and indeed the very existence of )  another affecionado of the style.  :D
Very valid point about the picking position ; as I think about my own natural picking postion ( more based on the way I hug the guitar close ) - I am somewhere between the neck pickup and last few frets.  One of the things I love about the 20 fret 'all body , no neck' 175 style of guitar, is the fact that you have the strings running that unusually long distance , between machine heads and tail,  then you have a relatively compact 'working area' of shorter neck and heavier strings.  It really helps me get into the mindset of chord melody work , and the music itself.  As you said, the tone itself sounds sweeter and richer - and that way your personal  'sound' gets moulded  around your playing position.  I can imagine the unpotted Stormy Monday is a revelation unto itself !  The Hofner sounds like a great contrast ( feel wise ) - and of course they appear to be very well thought out / layed out from the player's perspective.  I would be interested to hear what you thought of the Manhattan, if you ever tried it.  :)
add4
« Reply #42 on: August 12, 2012, 09:55:31 AM »
one of my friend, pro jazz guitarist, has a great jazz 'bell-piano' tone out of an old ibanez saber with bkp emerald in it.. go figure . :)
my es335 does the adam rogers tone perfectly, but not really well the piano tone unless i use a booster that i built before it, then i bring back a lot of clarity and note separation.
Current: Emerald (n), The boss (b)
Had: Manhattan (n)
Wish list: VHII (n), Blackguard 50 (n)
Fourth Feline
« Reply #43 on: August 13, 2012, 07:21:09 PM »
No surprise there ;  with a resonant body - and a nice 'open' sounding B.K.P. in there, it will certainly enable the  'snake charmer' who plays it , to draw out lovely tones. I think that clarity and adjustability are the common thread(s) between all the B.K.P.  I have tried, from Stormy Mondays - to Warpigs.  Power need not be dull - and a responsive guitar is an excellent foundation to build on, be it solid, semi-solid or hollow.  :)
« Reply #44 on: August 15, 2012, 11:49:02 PM »
I can get a nice dynamic and open jazzy tone from my Mules too.
