I'm not a "metal" player — Nailbombs?
Started by crxsh, June 07, 2012, 03:33:14 PM
crxsh
Hi everybody. First post.
Bottom line: I want a more modern sound of my Les Paul. Currently have a set of pickups described as being "similar to Gibson 'T-top' or 'Pat#' pickups of the later 60's" ... and they're not really what I want at all.
Have listened to a a number of clips and loved all the clean tones I've heard from the Alnico Nailbombs... but operate more in the medium-gain area. So would I be overwhelmed by them? Or can they do medium gain well?
(Playing through a small Dr. Z combo, btw.)
I found them to be very tight and aggressive. They'll do a number of things, as will all of the pickups, but to me they always seemed to retain a 90s Metal feel to them. They're certainly modern. I found Holydivers and Cold Sweats to be a lot more versatile.
BigB
My usual we-agree-to-disagree here ;)
I'm not into metal, I don't listen to 90s metal, I don't play metal, and I quite like the RR bridge on my SG, even for bluesy stuff. Yes, it's a rather modern sounding pup, and yes it's quite tight and aggressive (well, the bridge at least, don't have the matching neck). Not my first choice for pristine clean tones, but I like it a lot for about-to-breakup to full out hi-gain tones.  Now there might be better options for modern mid-gain LP tones, I didn't try the whole BKP range ;)
Toe-Knee
I never really got on with the nailbomb at all.
However recently I spotted one super cheap so I grabbed it as I was undecided what pickups to put in my Swirl.
it works really well for the 80s rock/glam stuff that I use the guitar for.
https://bareknucklepickups.co.uk/forum/index.php?topic=27824.0
Please note this was recorded using a sing star mic so its not the best sample. A friends bringing his i5 over this weekend so I'll be doing some proper clips then
[url="http://www.backline.tk"]http://www.backline.tk[/url]
Non Biased Guitar Forum
[url="http://fret.boards.net"]http://fret.boards.net[/url]
Alex
I love the Nailbomb and think it's one of the best pickups ever in the history of pickup-making, but it does have a bit of an metal edge to it. I would rather recommend the Holy Diver, which is very similar, but more openly voiced, or the Black Dog, which is probably one of the most versatile pickups.
mongey
I dont think you'd be overwhelemd at all .
they are agressive sounding but no more than allot of PU's .
I have the alnico set and that guiatr is used for a wide range of sounds. some hevay chugging but rock/hard rock type sounds as well
I dont find it that hot at all . no hotter than a duncan custom 5 or soemthing
Maton- jazz/JB
Cole Clark -NB Neck ,  Apig
Mayones Setius - Juggs
Et Guitars Katana 7 -Juggs
Mesa Dual Rect
and more stuff
I would have a look at Rebel Yells too. They are very sensitive for the right height, but once found the sweet spot, you'll find it a great rockpickup (can do metal too) for a Les Paul.
crxsh
Quote from: Alex on June 07, 2012, 11:39:44 PM
Hmm... those two seem to have a more prominent midrange — which isn't really what I'm after. In fact, "fat" and "muscular" mids are almost the opposite of what I want. Can you recommend something more balanced in the BKP lineup?
crxsh
Quote from: Toe-Knee on June 07, 2012, 07:19:55 PMA friends bringing his i5 over this weekend so I'll be doing some proper clips then
I'd really appreciate hearing some some low/edge-of-breakup and mid gain tones if you've got time. :)
The Abraxas has a quite flat eq, does Satrania-stuff in spades and cleans up great. Splits good too.
TheyCallMeVolume
I think you're looking for a Rebel Yell. Sounds great for what you want to do, I have a pair and I definitely highly recommend them.
crxsh
Quote from: allstar100595 on June 08, 2012, 03:47:00 AM
Just listened to the clips... those sound really good. Will definitely look into the RY's now.
I got a nailbomb bridge in my LP clone and I like it a lot. To me it's really aggressive and it took some time getting used to this, but it's very versatile at the same time if you use the volume and tone controls.
I would agree that an A-Bomb would be good in a Les Paul and my problem was the guitar I put it into BUT, for what the OP wanted, I just think it's too aggressive. If the Rebel Yell has the aggressiveness toned down a bit (never tried one myself) then that could be an ideal solution as I believe it was developed from a Nailbomb.
If the A-Bomb is too aggressive the Rebel Yell may be too aggressive as well. I would strongly consider the Abraxas instead.
