OTHER PICKUPS FOR MY ESP SVII CAMO
Started by GUAMAIK, June 14, 2012, 04:00:05 PM
GUAMAIK
HI Guys, I have this guitar loaded with 81/81 set, sounds good but I want a little more presence and bottom end, I am running tru a JCM 2203KK head, mesa cab WGS retro30s 4x12 and custom 2x12 WGS ET65 and VET30.
My style is more a mix of modern/melodic and technical death metal (COB, devildriver, in flames, soilwork), tuning Drop C and 10-50 DR strings. To me sounds good but I wonder if I install some other pickups can achieve better sound, I was thinking in passives and bareknuckles souns the way to go.
See my guitar specs: ESP SVII
SPECIFICATIONS CONTROLS
Neck-Thru-Body
25.5" Scale
Alder Body
Maple Neck
Ebony Fingerboard
42mm Locking Nut
Thin U Neck Contour
24 XJ Frets
Black Nickel Hardware
Gotoh Tuners
Floyd Rose Original Bridge
EMG 81 (B & N) p.u.
Finish: UC (Urban Camo)
Master Volume
3-Way Toggle
Esp SVII Cammo 2010/BK WP
Esp Custom Shop LP (Navigator Baged ESP) 1998/BK AM
Esp Custom Shop Stef 7 2005/EMG
Ibanez prestige RG1527 2006/Lundgren M7
Ibanez RGD7421 2012 modded/BK JN
Kramer EVH copy
Alex
Miracle Man! More sound than the EMG!
TheyCallMeVolume
GUAMAIK
What about Ceramic Warpigs? someone have tried those in alder wings, maple neck tru guitar?
Kramer EVH copy
asianaxeman
not as much bottom end, but for cob tones in drop c, painkillers in my ESP SV hit the spot for sure!
To me, this sounds like a job for a Miracle Man set or at least a Miracle Man bridge and maybe something else in the neck.
GUAMAIK
Well guys you are helping me a lot :D , Miracle man and painkillers then, but what would be the difference between those pickups?, which one do some better cleans, which is more modern sounding? what would suit better for rhytm and chugga chugga? :P
Kramer EVH copy
asianaxeman
#7
output similar
miracle man more bass, lower mid, slightly smoother highs
PK more upper mid, cuts through better in a live mix, extremly articulate, note separation is incredible, whereas MM sounds a little smoother in the midrange
both do pinch harmonics well
both pretty aggressive pickups, especially when you use a boost
painkiller neck most modern sounding out of all of them, more single coilish, drier, extreeeeemely articulate for shreddy leads and unforgiving, mm neck more fuller sounding with more sustain, both similarly compressed
coil split for cleans mm neck sounds the best
for alexi's tone, definitely the painkiller
chugga chugga- both rule!
old mm clip i did http://www.youtube.com/watch?v=jSxRi3GkyTg
GUAMAIK
 :D Thanks man..so I think I will go for the PKs set, so the wait for those from UK to Brazil..loong wait!..Thanks a lot to every one, I probably buy another set for my les paul full thickness ESP LTD EC-1000 and have it shipped at the same time, great tone with the SD alnico proII but not enough for metal, and I want this territory. I will write another post 8)
Kramer EVH copy
