Problem with grounding wire on telecaster bridge
Started by Mr. Air, June 17, 2012, 08:04:16 AM
I'm trying to solder the ground wire to my tele's bridge, but the surface is so smooth that the it won't stick. Any good suggestions?
Toe-Knee
Take a bit of sandpaper to it or a screw driver to scratch it up a bit this should help the solder to take.
Also make sure that you are heating the bridge enough with the iron otherwise the solder wont flow onto it.
[url="http://www.backline.tk"]http://www.backline.tk[/url]
Non Biased Guitar Forum
[url="http://fret.boards.net"]http://fret.boards.net[/url]
Do you mean the guitar's bridge, or the baseplate of the bridge pickup?
I don't see why you'd need to solder a ground wire to the bridge, string grounding on a Tele is normally via the pickup's baseplate.  If there's no pickup baseplate (like on some recent American Standards), Fender use a separate ground wire which sits under the bridge, but it's not soldered, it's just held in place by the contact between the bridge and the top of the body.
yeah, good contact is usually enough.  i tend to go with a wire stripped back with about 1" bare metal.  Then poke it slightly into a screw hole
only time you have to be a bit more thorough is with some black platings
frankus
you could just use a bit of shielding tape to stick it in place :) I generally shield the cavities and leave a lip of a cm or so running towards the saddles, then solder the wire to the shielding.
