Help! My Engl Powerball just Died!!!!!!
Started by BigK, July 18, 2012, 05:58:31 PM
BigK
As the title says my Powerball just died.
I turned it on loud static like noise (first i thought it was picking up a cb radio) then strummed a few chords and all seemed fine. Then there was a couple of loud pops and no noise.
The LEDs were still ON on the front of the amp, but then I caught a whiff of burning and immediately turned it off.
Could it just be the power valves failing? I've not changed them for quite a few years? anything I should check before I start throwing cash at it?
+ Can anyone recommend an amp tech in the Stoke/Stafford area?
PRS Tremonti - PRS Silverburst 594 - Ibanez RG550EX, RG570 & RG721FM - LTD SC 500 -  Schecter 006's - EVH 5150III 50w into custom Zilla Vert 2x12
Toe-Knee
#1
This exact thing happened to a friends bugera and it was one of the screen resistors that burnt out.
If you are comfortable with taking it out of the headshell and taking a photo that would help.
Also did you notice if there was any redplating going on?
[url="http://www.backline.tk"]http://www.backline.tk[/url]
Non Biased Guitar Forum
[url="http://fret.boards.net"]http://fret.boards.net[/url]
BigK
Quote from: Toe-Knee on July 18, 2012, 08:01:55 PM
I quickly looked at the valves before I shut it off and they looked normal to me.
I took the chassis out of the case but all the PCB's are upside down and its not completely obvious how to release them - although I've had a couple of whisky's so I'll look again in the morning.
I can't see any burning around the pcb. Ive had a quick look around valve sockets and cant see much.
Will get some pics tomorrow.
Frank
You can't usually tell if a tube's developed an internal short just by looking at it. Loud pops could mean a tube going bad, the burning smell could mean a resistor going open circuit, maybe a coupling cap has blown open or if you're very unlucky then it's a transformer problem.
A quick look at the PCB - when you're fully sober - will probably show up an obvious dead component.
BigB
Quote from: Frank on July 18, 2012, 11:21:15 PM
One cannot stress this enough :  "when  you're fully sober".  The power supply caps store lethal voltages (400+V DC) for many hours after you unplugged your amp, so better a dead componant than a dead guitar player.
and this will be my 1000th contribution to this forum... hopefully a useful one :mrgreen:
Quote from: BigB on July 19, 2012, 09:49:55 PM
A very useful one which I fully support - the voltages in a tube amp must be respected at all times.
BigK
I've finally got round to sorting this out as I've been using my Peavey Vypyr 30 for a while as my focus moved to my car for a while.
Anyway it was a dead power valve so I replaced the JJ's that were in there with a set of cryo JJ's and had it re-biased and it sounds better than ever!
Although it might not be around fro much longer as a secondhand mesa Roadster has popped up nearby that I might not be able to say no too.  8)
