Author Topic: Fitting a neck. Sand the body/neck?  (Read 4435 times)
James_B_K_P
  • Aftermaths
« on: July 20, 2012, 11:17:45 PM »
Can anyone answer this question? I've searched what feels like the whole internet and as usual nobody can give a definitive answer. I need to sand about 1mm to fit the neck into the pocket. Question is, do I sand the body or the neck? The body is an unfinished Ibanez Iceman/Destroyer Hybrid and the neck is an Ibanez Wizard 3. Cheers for any help :)
Aftermath Set
Andrew W
Re: Fitting a neck. Sand the body/neck?
« Reply #1 on: July 25, 2012, 09:43:02 PM »
When I had to do it to build my Mk II Telemaster I sanded the pocket as I had more faith that the neck I had was the "correct" size. It was a Warmoth neck and the body came from MJT. I also felt I had more control on keeping edges straight and proper by sanding the pocket. My two cents.
James_B_K_P
  • Aftermaths
« Reply #2 on: July 25, 2012, 11:47:59 PM »
Thanks Andrew! I already went ahead and sanded the neck, I got impatient! I read somewhere that it's important to keep the walls of the neck pocket perfectly level and it's pretty hard to do when sanding. It's a super tight fit though and feels great. The neck was second hand anyways!
Aftermath Set
