Author Topic: Trilogy with Dimarzio Protrack (neck) and Tonezone S (bridge)  (Read 4178 times)
stratfeelblues
Hello
I have a AM STD Strat having a Dimarzio Protrack (neck) and Tonezone S (bridge). At the moment I have a single for the middle (Lace Sensor Hot Gold) but I want to change this, it is not really adapted (volume difference, and even in 2 and 4). So I was OK at the beginning but not now.
I have the idea to mount a Trilogy on middle, all with 500K pots. I think it should be OK. Has someone experience on this kind of configuration.
Actually, I have another Strat with 2 Trilogy (Neck / Middle) and a Crawler in bridge and 500K pots , it works really very well.
So I think it could be good with the Dimarzio, but I am interested to know if someone has experience with that or something similar
Best regards
Stephane
Re: Trilogy with Dimarzio Protrack (neck) and Tonezone S (bridge)
« Reply #1 on: July 31, 2012, 09:03:51 AM »
The TS looks like the obvious choice, unless you want something more vintageclean from the middlepickup. Why not change the bridge too? I had a Tonezone T in my tele and it was undefined and muddy, but that's just my opinion.
« Reply #2 on: July 31, 2012, 09:46:32 AM »
I tend to agree (a sinner would be great in the bridge)
  • Random Solution
« Reply #3 on: July 31, 2012, 09:49:48 AM »
When I installed Trilogy Suites in my Jackson I really wanted stacked humbuckers so I seriously looked at a number of DiMarzio options but I eventually went BKP because I felt I'd always be left feeling I'd settled for second best if I didn't. Even a guy on the DiMarzio forum told me that! However, if you really like the existing pickups that you have in there, the Trilogy Suite is never a bad option to add to it.
stratfeelblues
« Reply #4 on: July 31, 2012, 07:35:37 PM »
Thanks for your advises.
I think I will process step by step, first the middle with a Trilogy and maybe after I will change the bridge.
For this next step, I wonder if the Stockholm could be a good option, looks OK in terms of output, P90 sound should be nice with the other pickups and in that case I have just the pickguard to modify.
Stephane
Alex
« Reply #5 on: August 01, 2012, 02:21:59 PM »
One problem might be the different output levels. Many DiMarzio unfortunately are very loud and compressed, whereas BKPs tend to be on the quieter side.
stratfeelblues
« Reply #6 on: August 01, 2012, 07:13:16 PM »
Yes that is correct , BKP are very defined unlike a DiMarzio Tonezone. That is why maybe I would go to change it with a Stockholm in a next step. Actually maybe after adding the Trilogy I will not be happy the Tone zone S. However, at the moment, I really appreciate the Protrack, very different, warm on clean , nice crunch and lead sound also
Let's see...
case report
  • Aquila non capit muscas
« Reply #7 on: November 05, 2012, 11:07:32 AM »
Which DiMarzio humb (single sized) you'd choose on neck with holydiver bridge?
Gibson Les Paul Historic 1958 - Stormy Monday
Charvel San Dimas - Holydiver (b) -Crawler (n)
Jackson Fusion Pro - Holydiver & Trilogy Suites
