Author Topic: Mississippi Queen question  (Read 2204 times)
Deafcat64
« on: August 04, 2012, 03:31:02 AM »
Just picked up a Mississippi Queen neck pickup, and I was thinkin about the pickup being covered. In one of the other posts, someone mentioned that pickup covers smooth, or round the highs a bit. Does this take away some of the P-90 "grit" and character? I got a great deal on the pickup. It's brand new and I was looking at getting a MQ neck to go with my Abraxas bridge, but I was trying to get some feedback on the compatability of the MQ and the Abraxas before I went that route. The opportunity to buy this one for a lot less popped up so I went for it.
Anyone have any input on the cover and how well it mixes with and Abraxas?
Thanks for any help!
1990 G&L S-500, SG Standard
Abraxas, Mississippi Queen
WeAreNotGentlemen
Re: Mississippi Queen question
« Reply #1 on: August 04, 2012, 03:48:06 AM »
This only applies to humbuckers. If the poles are covered I'm pretty sure something is very wrong. I don't think anyone makes P90's with the poles covered.
Deafcat64
« Reply #2 on: August 04, 2012, 04:32:31 AM »
No,it's a normal MQ. I was curious, because there is not an option for plastic covers only the standard nickel covers. I know that the slug coil on humbuckers have no holes. So you're saying that covers only affect the tone if the pole pieces are covered?
WeAreNotGentlemen
« Reply #3 on: August 04, 2012, 05:07:50 AM »
Well, in reference solely to P90's, as all of them are covered, yes. If you somehow uncovered the rest of the pickup I can't see why the tone would change. Please, someone correct me if I'm wrong.
Also I have the option for black/camo/tyger covers when I go to the shopping area of BK's site.
Fourth Feline
  • Ten minutes, then you really should practice ...
« Reply #4 on: August 04, 2012, 12:29:58 PM »
As WeAreNotGentlemen mentioned, the phenomena ( of a pickup cover slightly altering the tone ) only applies to Humbuckers or ( for example ) Telecaster neck pickups, where some , or all of the polepieces are covered.  In the case of B.K.P covered Humbucker pickups, I thought I remembered reading that they add a bit more to the winding, which minimised differences ( although an un-potted humbucker will sound different / more open ) .
Twinfan on here, once mentioned that he felt the M.Q was not a typical P90, as it was fatter and less grinding. I can confirm those attributes as being true - and indeed were the very quality that I bought mine for .  :)
Plenty of cut and snap still available though ; try the M.Q pickup at a slightly greater distance from the strings, as I found more snap and cut at  => 3mm - and thicker / hotter sounds at 2.0 - 2.5 mm.
The overall effect has a lovely smoothness to it though, without ever being 'tame'.  I feel sure you'll have a lot of fun from the M.Q. - and although I've never mixed it with another type of bridge pickup - the M.Q. neck has enough output to hold it's own ground .  :)
« Last Edit: August 04, 2012, 12:33:19 PM by Fourth Feline »
BKP Manhattans, Stormy Mondays,  Mules , Missisippi Queens , ( Alnico) Warpigs - and VHII Bridge.
Deafcat64
« Reply #5 on: August 04, 2012, 01:53:05 PM »
I'm familiar with p90s. I've used several in the 30+ years I've been playing guitar. There are options for finishes, but the covers are still metal, not plastic, like a normal P90. A friend and guitar tech said that it's highly likely the metal cover will make the MQ slightly "smoother" than a plastic covered P90. The nickel cover, while not magnetic, will still have a slight affect, though it may not be a noticeable one in a band environment. I'm hoping to get a nice, rich P90 tone. As long as it retains the basics of a traditional P90, I'll be happy!
