Author Topic: what Pickup for my 1987 Jackson Strat  (Read 4677 times)
fredberu
« on: August 09, 2012, 09:46:39 AM »
Hi everybody!!!
i own a (fast playing) Jackson Strat with particular spec. :
poplar body
maple fretboard/maple neck
five way blade
and kahler trem bridge
few pics for an idea :
i would like to change those 2 jackson Humbucker for Bare Knuckle pickup, but i never did have occasion to play bare knuckle pick up..
According to the spec. of this strat (poplar/maple fretboard and neck) what BK humbucker would you recommend me for a heavier sound than those Jackson pickup (how are low and less powerful)?
i don't want a too modern sound like aftermath..i'd rather have something strong but no to mechanical for bridge,and something good for solo/shred in neck position..and..of course, with good clean sound!!
the nailbomb, painkiller , miracle man and holy diver are the humbucker i've heard..but maybe there are others one or other combination according the strat spec.
thanks a lot for reading!
fred
Madsakre
Re: what Pickup for my 1987 Jackson Strat
« Reply #1 on: August 09, 2012, 09:51:29 AM »
HOLEH DAIVAH!
Cattlepress
itamar101
« Reply #2 on: August 09, 2012, 09:55:25 AM »
HOLEH DAIVAH!
:D
This or the miracle man.
Not the painkiller. Itll be far to bright for a maple neck bolt-on.
Madsakre
« Reply #3 on: August 09, 2012, 10:38:29 AM »
Unless you play grindcore ^^
Cattlepress
fredberu
« Reply #4 on: August 09, 2012, 10:42:42 AM »
thanks for all your answers guys
@madsakre : i like few grindcore bands (haemorrage , brutal truth etc. ) but i don't play grind
i got a Kelly Custom Shop with Sh6/'59  for play old school death metal
with the strat i'ld like to have something for metal/heavy metal (maiden, metallica etc.)
what about a set : nailbomb (bridge)/holy diver (neck) ?
does the holdy diver , in bridge position, would fit for what i want to play with the strat ?
« Reply #5 on: August 09, 2012, 10:45:14 AM »
Rebel Yells will work well , or Miracle Man
Poplar is often a tricky body wood to get a good match with
I actually think that the Painkiller might work well - but it will be bright
I would look at swapping the cap on the tone pot for an paper in oil variety like a Jensen 0.022uF
Or swap out the whole wiring harness for CTS pots and a Jensen (if the pots are not CTS ones)
itamar101
« Reply #6 on: August 09, 2012, 06:37:16 PM »
I wouldn't get a nailbomb for those bands or a holy diver neck.
I'd actually get a cold sweat neck and a holy diver bridge (perfect maiden tone) or a miracle man in the bridge if you want slightly more aggressiveness and a slightly more scooped sound.
« Reply #7 on: August 09, 2012, 07:25:41 PM »
Another vote for the HD/CS-combo. Should serve all your needs.
  • Random Solution
« Reply #8 on: August 09, 2012, 07:38:07 PM »
+1
From what you've said the Nailbomb would be too much as it's modern, very tight and very aggressive. The Holydiver in the bridge will give you a very smooth 80's Metal tone with a nice touch of aggression to it. I think you'd actually like a touch more aggression so I'd make the Miracle Man my first choice as it's in the same tonal ballpark but with a bit more tightness and aggression but still thick and smooth. For the neck, you can't do better than either a Cold Sweat or Emerald.
fredberu
« Reply #9 on: August 10, 2012, 08:48:09 AM »
thank you all!  :wink:
i think i'll go for a Miracle Man (bridge) / cold sweat neck
I guess i might choose short leg/4 conductor/ and 53 bridge spacing (for the Kahler bridge?? or i might choose 50'?)
« Reply #10 on: August 10, 2012, 09:33:33 AM »
Miracle Man bridge/Cold Sweat neck will definitely work well, even if the Miracle Man has quite a bit more output.
I definitely would not pair the Alnico Nailbomb with the Holydiver neck - the NB being a hot, dark and sizzling pickup and the HD-n being a low output and clean sounding pickup it would not be a good match - neither from an output nor from a tonal perspective. The VHII neck would be a better match for the A-Bomb bridge IMHO if you don't want the calibrated set.
