Author Topic: 2 Humbuckers 2 vol 3 way blade switch  (Read 6553 times)
Dormin
« on: August 26, 2012, 06:23:43 PM »
Hello folks  :D I just recently purchased a calibrated set of 2 conductor Aftermaths for my Ibanez  RGT42FX.  I want to attempt to wire these guys up my self but I'm a bit unsure of a proper way of doing it.  Basically I want a volume pot for each pick up, no tone pots and a 3 way blade switch (8 terminal) to go bridge bridge/neck neck.  I don't see a link to that exact schematic on the BKP site and after attempting on paper to make 1 line diagrams of how I think it should work, I'd rather ask for help from someone who may be sure how its done correctly,  thanks ^^
Frank
Re: 2 Humbuckers 2 vol 3 way blade switch
« Reply #1 on: August 27, 2012, 12:28:36 AM »
Uncle Seymour is here to help ...
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=2h_2v_2t_3w
Just omit the two tone pots, ground everything onto the backs of the volume pots. The red and white coil joins don't apply either as those are already done inside the pickup if it's two conductor.
