Author Topic: Strat - irish Tours - Squealing?  (Read 2384 times)
mkh02
« on: September 04, 2012, 09:01:37 AM »
Hey guys recently purchased a warmoth strat from a friend with Irish tours in.
it is easily the best strat i have ever heard or played but the bridge pickup seems to be squealing at mid to high gain?
I wouldn't say it is the general feedback that I would expect from say a humbucker on high gain where it is more a nice high pitched sounding harmonic that can be blended with the song...
It is really a very high pitched screaming/ squeeking noise. If i dial back the volume nob on the guitar to say 8 the squealing stops but if I put it back to 10 then it is very very loud.
It doesnt squeal in the bridge or mid pickup...any thoughts?
My other strat had a single coil bridge in it but I changed it to a humbucker years ago but to be honest i don't remember it squealing that loudly...
Many thanks for any help or advice!
Re: Strat - irish Tours - Squealing?
« Reply #1 on: September 04, 2012, 09:17:22 AM »
Hi and welcome to the forum!
Take a pick and gently tap on the bridge, middle and neck pickups while the amp is at playing volume. If you hear a "click" tone with the bridge pickup which is noticeably louder and more metallic  than with the other pickups you have a microphonic pickup. Take the pickguard off (or let your tech take it off) and check whether the bridge pickup has a metal base plate. If so, check whether it is solidly attached to the pickup - if it is loose, that can cause squealing problems. The solution then is either to remove the base plate or to solidify the joint between pickup and base plate. Since I have never done this I cannot give you a detailed description of how to do it.
If you don't have a base plate you may have a microphonic pickup. This can be cured by wax potting the pickup. I believe BKP does this service, too.
mkh02
« Reply #2 on: September 04, 2012, 09:42:03 AM »
Thanks for the quick reply mate!
I am of course aware that single coil pickups carry with them more 'noise' in general compared to humbuckers but this one is really like a banshee screaming when I turn the gain up...will follow you advice and see what happens!
« Reply #3 on: September 05, 2012, 12:13:13 AM »
The IT should not squeal. There's is something wrong. Stephan already gave good advice. I never had any squealing-issues with the BKP's I own. They are silent compared to a lot of other pickups I had.
Tim
  • BKP
« Reply #4 on: September 06, 2012, 09:01:05 AM »
Sounds like microphonics to me - just needs repotting.
Tim
