Author Topic: Carlsbro PM10 circuit diagram  (Read 7940 times)
psy
    • Me singing & guitaring
« on: September 10, 2012, 11:55:58 AM »
Hi,
Does anyone know where I can find a circuit diagram for a Carslbro PM10 stage monitor?  A cap has blown & I can't find the outer casing to see what size it was to replace it.
Cheers,
Simon
Re: Carlsbro PM10 circuit diagram
« Reply #1 on: September 10, 2012, 08:31:48 PM »
Have you tried calling Carlsbro? - not trying to be a smart arse, but thats the most direct route imo.
psy
« Reply #2 on: September 10, 2012, 09:36:43 PM »
No, not yet.  I was hoping to just find a schematic online somewhere.  I'll try giving them a bell, they might even know why the capacitor in the same position has exploded twice now. :)
jpfamps
    • http://www.jpfamps.com
« Reply #3 on: September 10, 2012, 10:44:58 PM »
I firstly assume the cap is an electrolytic.
If it's a signal/ decoupling cap, then it will most likely expire due to over voltage, although it can also expire if it is near a source of heat.
It is a filter cap it could also expire due to poor ripple current rating, which causes self heating.
I've seen quite a few piece of equipment where the voltage compliance of the caps is exceeded in normal use.
When you replace the cap I would go for 105degC cap (regular caps are rated at 85degC; all things being equal the 105degC cap will last 4 times as long as the 85degC cap) rated at a higher voltage.
Of course there could be another problem with the unit which is causing the cap to expire, but I would go down the uprating route first.
psy
« Reply #4 on: September 11, 2012, 08:49:35 AM »
Hi JPF, yeah it's an electrolytic cap.  Thanks for the tip on using one rated for a higher temperature.  I remember it being 100v, but I don't remember the other figures on it at the moment.  As a general rule would putting a cap rated for a higher voltage in be a bad idea?  Just thinking if that couple with a higher temperature rating might double my chances of it not blowing again.
Cheers,
Simon
jpfamps
« Reply #5 on: September 11, 2012, 11:52:46 AM »
Higher voltage rating is fine.
Lower not so good......
« Reply #6 on: September 14, 2012, 11:46:49 PM »
Good for bonfire night  :lol:
