Author Topic: need help for multipurpose humbuckers  (Read 2987 times)
rmydelmas
« on: September 24, 2012, 01:34:37 PM »
Hello!
I'm looking for two humbuckers, I need multipurpose microphones, I'm playing Jazz and also metal, rock. I'm using a fender super reverb on clean sound, and soldano for high gain. my guitar wood is poplar. So I need my "bridge metal tone humbucker" to be harmonized with a "clean great sounding neck-pickup". Also, I need them to be splittable in single coils.
I forgot to say, I need them passives.
Does anyone has an idea of which Humbuckers should I buy, what material?
Thank you for your help!
« Last Edit: September 24, 2012, 01:37:59 PM by rmydelmas »
dingleberry
Re: need help for multipurpose humbuckers
« Reply #1 on: September 24, 2012, 02:24:13 PM »
Perhaps Blackhawks, four conductor wire for coil splitting
HD b, VHII n, BD b, Mule n
rmydelmas
« Reply #2 on: September 24, 2012, 02:59:12 PM »
thank you I will find out!
BigB
  • Let's rock !
« Reply #3 on: September 24, 2012, 07:02:07 PM »
There are quite a few distinct "metal tones" out there so you should perhaps tell more about this part. Now, I never played them and don't know if they'd belong in poplar, but Warpigs are known to deliver both metal and jazz tones...
All BKPs buckers can be ordered four-braided - but don't expect a split Gibson-type 'bucker to sound like a Fender SC (even if most BKPs buckers are known to split well).
Did you spot any active pickup in the BKP range ?-)
rmydelmas
« Reply #4 on: September 24, 2012, 07:52:27 PM »
Thank you for the Warpigs,
I will tel you more about what i am looking for:
I thought a combination of two different microphones, like a vintage or vitage hot for my neck pickup (that I use for blues jazz clean crunch sound on my fender amp) and a contemporary one for my bridge (Metallica tone for example), and i would like to use it together sometimes.
BigB
  • Let's rock !
« Reply #5 on: September 25, 2012, 05:58:20 PM »
If you were using a SG (or similar mahogany plank guitar) I'd suggest a Mule neck / Abomb bridge then, but I'm not sure they'd work fine on poplar which is already rather bright and snappy IIRC.  The Crawlers are known to be a good fit for fenderish guitars and are quite versatile but the bridge might not be modern enough for you.
How does your guitar sound unplugged BTW ?
  • Brokeback is back
« Reply #6 on: September 25, 2012, 06:36:25 PM »
What about a Holydiver bridge and a Mule neck. The Holydiver is said to work really well in alder and poplar is quite similar to alder tonewise (as far as I know). With a high gain amp like a soldano the Holydiver should easily spit out some metal tones.
« Reply #7 on: September 26, 2012, 12:14:16 AM »
+1, or the Nailbomb-bridge which is more agressive.
BigB
  • Let's rock !
« Reply #8 on: September 26, 2012, 09:51:20 PM »
The ABomb might actually be too aggressive in a poplar guitar. I never played a Holydiver but given the reviews and soundclips I think it could be a better fit here.
« Reply #9 on: September 27, 2012, 12:34:33 AM »
Personally I would favour the Diver in most cases, also in this one. But I had a Gibson MIII and that one was not so bright as I expected, despite the maple neck and the poplar body. It once emphasizes that the natural voice of the timbers should be considered when making a choiche for a pickup.
