Author Topic: Bright sounding Les Paul  (Read 5540 times)
David
« on: October 10, 2012, 12:07:47 AM »
I run a 2010 Les Paul Studio - Chambered. It has stock pickup 498t/496r. Sound is thin has no authority to it.
Amp is a Randall rm100 with 2 6l6 and 2 el34 power tubes. Wondering what pickup would thicken up the bottom.
TheyCallMeVolume
Re: Bright sounding Les Paul
« Reply #1 on: October 10, 2012, 12:23:51 AM »
First ones that come to mind for me are Holy Divers or Black Dogs. Depends on a lot of things though. What are you using it for?
« Reply #2 on: October 10, 2012, 03:40:54 AM »
Depends on what styles you play.
Black Dog for thick, open vintagehot PAF-tones.
The Diver could be an option for modern styles, does have not that much bass.
A good compromise would be an Abraxas, which has PAF-pedigree and is able to do modern rock too.
« Reply #3 on: October 10, 2012, 05:45:01 AM »
alnico nailbomb for the bridge, vhII for the neck
« Reply #4 on: October 10, 2012, 10:20:17 AM »
I am not familiar with the Gibson 498T but the Holydiver does not have too much bass. For that purpose I would look to the Alnico Nailbomb, the Miracle Man or the Alnico Warpig.
I am also not familiar with the 496R. VHII neck is a good match for the Alnico Nailbomb in the bridge. For the other two I would choose something hotter, i.e. go for the calibrated set.
David
« Reply #5 on: October 10, 2012, 05:06:41 PM »
Style wise - self titled Alice In Chains-three legged dog  Also like Anthrax, Soundgarden. Consider No More Tears album to be "perfect" tone. I do use cleans- both pickups for clean( vol around 6/7 each, one pick up for slight break up cleans, vol 8/9.  Mostly standard tuning, lowest I go is drop D.
« Reply #6 on: October 10, 2012, 06:06:01 PM »
stock neck pup should be a 490r
496r is ceramic and way hotter
« Reply #7 on: October 10, 2012, 06:08:26 PM »
still alnico bomb/vhii, imo
maybe a neck miracle man in the bridge, if you want a fatter and darker tone (a lot like scott ian's custom shop pickup, by the way)
David
« Reply #8 on: October 10, 2012, 06:19:56 PM »
490 it is. The Miracle Man set did strike my attention originally. Just didnt know if 1. it would be thick enough and 2. how diverse it is.
« Reply #9 on: October 10, 2012, 06:31:07 PM »
the regular ceramic bridge miracle man has a lot of treble, although it's not a bright voiced pickup
the neck alnico version is a little less hot than the bridge, but fatter and darker, definitely more appropriate for your objectives
they're actually the same pickup with different magnets
David
« Reply #10 on: October 10, 2012, 07:13:03 PM »
Would there be any issues with using alnico Miracle Man for both bridge and neck.
One thing I don't want is a large volume drop when switching from bridge to neck.
« Reply #11 on: October 10, 2012, 07:25:41 PM »
probably, depending on height settings
I wouldn't go with the MM on the neck position in any of your cases, anyway
I'd stay between 8k and 10k
the neck vhII might be a good match for the alnico miracle man as well
« Reply #12 on: October 11, 2012, 10:42:48 AM »
I guess that is right. Tim once recommended to me to use the Crawler neck with the Miracle Man bridge as that would be a good combination as well. So I don't really think you would have too much output drop.
Because it has thicker wire, the VHII should be hotter than the Cold Sweat neck which was a bit low in output compared to the Miracle Man bridge.
