Author Topic: Do unnessecary switches suck tone?  (Read 2613 times)
triantobebrian
« on: October 14, 2012, 02:46:14 PM »
Do (unnecessary) switches suck tone????
Hi all,
Building a Warmoth Strat with Bare Knuckle pickups and putting a Suhr noise (hum) reducing backplate on it.
I'm also going to put an S1 switch in to turn the backplate on or off. Why?? I don't know. - w*nk factor to be honest. if I ever want to hear the hum (why would you you ask??? Dunno) I can turn the plate off.
But talk unnecessary switches...... Am I robbing myself of tone on such awesome pickups just so I can pimp my guitar????? Or will an S1 not make much of a difference....
Cheers.
BigB
  • Let's rock !
Re: Do unnessecary switches suck tone?
« Reply #1 on: October 15, 2012, 09:03:17 AM »
From a purely technical POV, just anything you add between your pup and your amp will impact the signal. Practically, with a decent quality switch and a clean soldering job, I doubt you will hear much difference...
triantobebrian
« Reply #2 on: October 15, 2012, 11:27:53 AM »
Thanks.
I think I'll do it.....
TheyCallMeVolume
« Reply #3 on: October 15, 2012, 02:07:04 PM »
Shouldn't make that big of a difference.
BigB
  • Let's rock !
« Reply #4 on: October 15, 2012, 07:47:43 PM »
Yeps - much less than a bad quality cable... :mrgreen:
« Reply #5 on: October 16, 2012, 01:56:54 AM »
Or bad stompboxes, or cables / signal chains that are too long, or the age of strings,....
« Reply #6 on: October 16, 2012, 09:01:30 AM »
The switch will rob less tone than the noiseless plate. You will hear the difference ant it will sound more open, brilliant with the noise plate off. However, well there will be noise  :P
« Reply #7 on: October 16, 2012, 09:53:47 AM »
I've never tried the Suhr system but I have tried lots of hum-cancelling Strat and Tele pickups.  They're great, but they never sound quite as good as true single-coils - even though I do hate the hum and it feels like a relic of the 1950s which we "should" be able to eliminate.  :wink:
So I think Hunter's right - it's probably almost better not to have the option of switching the noise cancellation on and off, because it will sound better off!  And therefore both settings are somewhat compromised in different ways.... which may or may not get on your nerves.  :lol:
On the other hand, I suppose you then have the option of only using the Suhr system when hum is actually causing a problem.
(And I don't think the presence of the switch itself is going to compromise the tone)
« Reply #8 on: October 17, 2012, 02:43:03 PM »
+1.
