Author Topic: It's become about valve pedals...  (Read 3606 times)
juansolo
    • Juansolo's Gnomepage
« on: October 30, 2012, 04:08:43 PM »
Yay!
« Last Edit: October 31, 2012, 07:27:03 PM by juansolo »
juansolo
Re: Klones, reverbs, noise gates and wotnot.
« Reply #1 on: October 30, 2012, 04:12:14 PM »
Arse, someone want to nuke this, was supposed to be in seconds out.
CanadianMetalhead
Re: Please delete this
« Reply #2 on: October 31, 2012, 08:11:33 AM »
NEVAH!
you must live your shame of wasting ultra valuable forum space!
=P
PU's owned : AWPb, CWPb, MMb, CSb, HDb, HDn, Mule n, VHII b+n
juansolo
« Reply #3 on: October 31, 2012, 08:56:06 AM »
 :oops:
« Reply #4 on: October 31, 2012, 04:48:36 PM »
I'll make some use of it, then  :lol:
hey, juan
got your baby cat pedal from twinfan
sounds pretty nice as a clean booster or straight to the loop  :D
can you tell me more about it?
why did you choose the 6br7 over a regular 12ax7?
juansolo
« Reply #5 on: October 31, 2012, 07:16:11 PM »
It's essentially the first stage of a Vox AC30 running starved plate (60v in this case). It's a pentode rather than a triode so don't stick a 12ax7 in there, it won't work ;) It works really nice as a valve boost. It's probably most like a smoother and gruntier SHO. We use a 6BR7 as it's essentially an anti-microphonic EF86.
We do a triode based one also, that's different again (it's actually a heavily modified Valvecaster and sounds nothing like one), more of a smooth treble booster. That could use a 12ax7, but we run them with 12AU7A RCA cleartops as they were a great sound with low current draw.
We can do the pentode boost using a sub-mini missile guidance valve ;)
I'm a big fan of both. They really add to my low wattage single channel amps.
Good to see that it was snagged by another forumite.
« Last Edit: October 31, 2012, 07:25:03 PM by juansolo »
marauder
Re: It's become about valve pedals...
« Reply #6 on: November 01, 2012, 06:56:13 PM »
Don't put an EF86 in it either, the pinouts are different, even though they are very similar sounding.
  • Truly bad since 1972
« Reply #7 on: November 03, 2012, 07:46:52 PM »
so valve pedals for sale?
juansolo
« Reply #8 on: November 03, 2012, 10:50:45 PM »
Can make 'em, certainly.
