Author Topic: BKP for PRS SE Tremonti to cover more different sounds?  (Read 3189 times)
rallax
« on: November 15, 2012, 09:09:18 AM »
Hi all,
I want to replace stock pus of my new PRS SE Tremonti (new modell w/tremolo) w/ BKP to archive a more broader sound spectrum. If possible I would like to from classic rock (I have a set of Riff Raffs in a Hagstrom Viking ES copy) to more modern rock sounds (A-bombs in a HH Tele Copy w/ maple body). In between I've the same HH Tele copy w/ Black Dogs. And some kind of British clean would not be bad. But I do not want to cover heavy metal.
Currently I'm thinking about VHII or RY.
I play a Splawn Street rod w/ covers modded Marshall sounds.
Any idea or recommendation for a BKP combination.
Up to now I'm very happy and satisfied w/ all recommendations of this forum.
Thanks a lot!
Greeting from Germany.
Ralf
Re: BKP for PRS SE Tremonti to cover more different sounds?
« Reply #1 on: November 15, 2012, 10:23:54 AM »
Rebel Yell set would be a good choice - bridge pickup has good power but not overbearing, neck pickup is clear and not muddy, and they are very balanced as a set.
The VHII neck is a good pickup as well. Never played the VHII bridge so I cannot really help here.
I would also consider the Abraxas set.
TheyCallMeVolume
« Reply #2 on: November 15, 2012, 11:41:34 AM »
RY's would be a great complement to your RR's and your ABombs. Can't go wrong there.
  • Brokeback is back
« Reply #3 on: November 15, 2012, 11:45:22 AM »
I would say VHII set or Abraxas set. I think the Rebel Yell might be a bit too close to the abomb.
darrenw5094
« Reply #4 on: November 15, 2012, 08:07:44 PM »
I have VHII's in a PRS CU22 and they cover alot of ground.
The Abraxas are hot, but still vintage voiced and balanced.
Can't go wrong with either of them.
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
« Reply #5 on: November 15, 2012, 09:20:05 PM »
Abraxas closed the gap between vintage and modern. VHII's are great too, genuine all purpose rockpickup.
ZeroFiveFour
« Reply #6 on: November 21, 2012, 04:36:41 AM »
Hi all,
Thanks a lot!
Ralf
Ralf,
I have a  PRS SE Single cut.  I went with a set of Rebel Yells.  It is a very versatile modern rock combo.
 The bridge pup can get down and dirty raunchy and is never mushy.  Very organic and less compressed than the dimarzios in my Ernie Ball Axis.  The bridge pup cuts and has awesome bite when playing power chords. It is absolutely smoking hot for solos.  The mid range is glorious.  Gnarly is the word I often use to describe it. The roll off is simply brilliant, from hot to mellow in an instant.   The bridge is a monster rock pup.  The neck is smooth as a baby's bottom, lush and chime'y'.  Bluesy and jazzy right up there with the best of them.  It is an extremely versatile set of humbuckers.
Hope this helps.
Cheers,
Tom
« Last Edit: November 21, 2012, 04:40:25 AM by ZeroFiveFour »
