Author Topic: Alternative to Alnico Nailbomb  (Read 4825 times)
drawnacrol
« on: November 19, 2012, 03:25:40 PM »
Hey! I have an Alnico Nailbomb Bridge in my Schecter C-1 Custom(Mahagony Body, Maple top, maple neck, ebony board). I like it for leads and power chord/chugging riffs but it comes out a little thin in this guitar for the style of metal I'm playing.
I'm looking for something thicker like the metalcore EMG sound but still retaining the tightness/smoothness of the Nailbomb. I'd also like a smoother high end and more modern voicing. The Nailbomb kills for rock and 80s metal but I'm looking for tones like Children of Bodom, Necrophagist, Protest the Hero, Wintersun.
Metalcore:
http://soundcloud.com/drawnacrol/bareknuckle-nailbomb-fas-6160
MAB rock riff:
http://www.youtube.com/watch?v=AxTls-lmhrI
Tight bass response with chunky palm mutes
Smooth/rounded high end for soloing
More modern voicing with a fatter sound to each note
Still retaining the overall tightness/low noise of the Nailbomb
I'm thinking the Holy Diver but how would the bass response compare.
« Last Edit: November 19, 2012, 03:27:59 PM by drawnacrol »
Re: Alternative to Alnico Nailbomb
« Reply #1 on: November 19, 2012, 05:37:31 PM »
I read here on the forum the NB has more bass then the HD. The HD has a prominent midrange and smoother, rounder topend.
Alex
« Reply #2 on: November 19, 2012, 07:36:39 PM »
Hm I felt the HD has more bass than the NB actually.
In any case, have you messed with the pickup height? I like the NB most when it is not too high.
« Reply #3 on: November 21, 2012, 04:03:46 PM »
I actually had them in the same guitar, and the Holydiver definitely did not have more bass than the A-Bomb. If you want an Alnico pickup with more bottom than the A-Bomb, the only BKP that comes to my mind would be a Miracle Man neck as a bridge pickup. Haven't tried this though.
« Reply #4 on: November 21, 2012, 06:58:06 PM »
That was my thought too.
schantist
« Reply #5 on: November 21, 2012, 07:59:44 PM »
I'm gonna throw in the Blackhawk with alnico bridge option...
  • Brokeback is back
« Reply #6 on: November 21, 2012, 08:32:48 PM »
Could a C-Pig work???
GuitarIv
« Reply #7 on: November 22, 2012, 10:11:22 AM »
What is this thing with the MM Neck in the bridge actually? I read it several times here on the forum, but has anyone tried it yet?
JimmyMoorby
« Reply #8 on: November 22, 2012, 10:48:55 AM »
Sounds interesting !
« Reply #9 on: November 22, 2012, 11:45:39 AM »
The Miracle Man bridge and neck pickups are pretty similar in their windings, but the bridge has a ceramic and the neck is alnico 5.
There is no reason not to use the neck version at the bridge - it will be a less midrange bloated Warpig territory  on paper as both have AWG45 wire on them - although the double screw coil does give some extra low end welly to the Warpig
drawnacrol
« Reply #10 on: November 22, 2012, 09:57:06 PM »
Cheers for all the replies lads!
If the HD is tighter then I don't mind less bass since thats the first thing I dial back on an amp anyway. The fatter mid range and smoother top end is definitely what I'm looking for.
Blackhawk would be a good choice but asthetically it wouldn't pair up with the covered cold sweat neck pickup.
Yeah I mess with the height but its a bit hard to find the sweet post when your using an Axe-Fx since there are so many signal input parameters.
Damn things get a lot more complicated when you start mixing and matching:L Using a dimarzio D-activator neck in the bridge is quite common so I'd love to try some BK necks in the bridge.
« Reply #11 on: November 22, 2012, 10:37:54 PM »
the diver has a bit less bass but it's not tighter than a nailbomb
center and upper mids are bumpy in comparison, but still softer
the neck miracle man is definitely worth a try if you want an even bigger sound
but the regular ceramic miracle man is still the perfect pickup for your style, in my opinion
drawnacrol
« Reply #12 on: November 26, 2012, 10:59:54 PM »
http://soundcloud.com/drawnacrol/bareknuckle-nailbomb-test
With some further in-depth tweaking on my Axe-fx I think I've got the tone I was looking for. It reminds me of the Holy Diver in my other guitar now but tighter and crunchier.
