Author Topic: Pickup for a Jackson Dinky JS1  (Read 3385 times)
Rohtagran
  • Eastern State
« on: November 21, 2012, 12:28:25 PM »
Hi,
I have a Jackson Dinky JS1, I think it has a basswood body but I'm not sure. It also has a maple bolt-on neck with a rosewood fretboard.
I really like this guitar although it's cheap. I recently joined a metal band and found the pickups are good (for i can say) but not good enough for me.
At the moment I still use my 10 watt beginners amp (the biggest reason my sound is cr@ppy) but I'm planning to buy a Peavey Valveking 112.
I'm also a big fan of Mark Morton's (Lamb of God) sound but also a fan of Mike Spreitzer's (DevilDriver).
Mark uses a Dimarzio Dominion a passive pickup and Mike uses an EMG 81. I'm looking for pickups that can help get the sound of one of those maybe in between.
Hope you guys n gals can give me some advice :)
~So I dub thee unforgiven~
Re: Pickup for a Jackson Dinky JS1
« Reply #1 on: November 21, 2012, 12:55:35 PM »
Hi and welcome to the forum.
Reading your description the Blackhawk comes to mind (its designed to be a best of both worlds kinda deal between active and passive). You should look into that one.
The alternative would be Miracle Man, the go to recommendation for all things modern metal and bands that normally use EMGs.
darrenw5094
« Reply #2 on: November 21, 2012, 01:54:59 PM »
Did you try your Jackson in a valve amp, ENGL or Mesa?
Maybe the pickups are fine in a decent amp.
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
Rohtagran
  • Eastern State
« Reply #3 on: November 21, 2012, 03:47:23 PM »
@Kiichi: thanks for the advice, I'm gonna some sound clips and video's of those.
@darrenw: I've tried the guitar trough a valve amp (the peavey valveking of an old classmate) and it worked well. The stock are (in my opinion) better than the GFS pickups in my other guitar. But I think they're aggressive enough.
Wish I could try the jacskon with a Dual Rectifier but those are way to expensive.
TheyCallMeVolume
« Reply #4 on: November 21, 2012, 03:59:29 PM »
I think Kiichi is spot on here, either Blackhawk or Miracle Man.
« Reply #5 on: November 21, 2012, 07:01:56 PM »
Good recommendations here, but I would invest first in a proper valveamp, like the Orange TH30 or something similar.
« Reply #6 on: November 21, 2012, 10:15:26 PM »
Yes if finances allow that I agree. The jump in sound quality will be much greater (and that way around youŽll truely be able to appreciate the BKPs).
Rohtagran
  • Eastern State
« Reply #7 on: November 22, 2012, 08:01:01 AM »
Thanks for the advice, I really appreciate it.
The first thing I'll buy will of course be a new amp, like i said in the first post I'm planning to buy a valveking 112.
The next thing will be new pickups. I hope to get them around Christmas next year (I hope Santa Claus has enough money :P).
Greets
Rohta :)
