Author Topic: PU for Jackson SL1 through Peavey 5150  (Read 1451 times)
MBKorn
« on: December 10, 2012, 12:26:30 PM »
Hi there
Im now pretty sure that i will get an Miracle Man for the bridge position on my Jackson SL1 (neck-through).
But what about the to single couls. Is the Trilogy PU to prefere or? And is it best to buy the HSS set or does it not matters (if i buy the hb-PU now and the single coils later). Can se the set of single coil is more expensiv than buying to single coul seperate).
Is there a good alternativ to the Trilogi?
Im playing metal (thrash, heavy and more aggresiv) and want to scoope sound from my amp.
Thanks, Michael
  • Brokeback is back
Re: PU for Jackson SL1 through Peavey 5150
« Reply #1 on: December 11, 2012, 05:53:53 AM »
I think the Miracle Man/Trilogies combo will be a good match. You can start out with getting the MM bridge and then add the singlecoils later with no problem.
GuitarIv
« Reply #2 on: December 11, 2012, 09:36:37 AM »
I got my Slowhands after my Holydiver and I have no problems considering output or volume, everythings balanced well :)
