Author Topic: Ordered the Wrong Leg Length for a PRS guitar  (Read 12417 times)
Djentleman!
« on: December 26, 2012, 06:11:47 AM »
Hello, I ordered a Aftermath for my PRS CU24's bridge...well I didn't do enough research and recently found out the half inch legs won't fit - only the short 1/4" legs do. I haven't received the pickups yet (ordered a month ago through another retailer...bad idea) and am hoping I can get that changed before they ship, but in the event I'm too late, does anyone know a solution to this (the legs being too long)? I will not do any routing or drilling to the guitar itself  :shock:
Re: Ordered the Wrong Leg Length for a PRS guitar
« Reply #1 on: December 26, 2012, 11:43:54 AM »
Can't you wait till they arrive, send them back and order an Aftermath with short legs? I would contact BKP about this.
« Reply #2 on: December 26, 2012, 12:29:04 PM »
I did this once and sent them back to BKP and have them swapped  :)
Djentleman!
« Reply #3 on: December 26, 2012, 05:15:49 PM »
How much extra did it end up costing you to do that?
Also, I've heard that the long legs can fit in a PRS Standard; can they also fit in a Custom 24? If so then I've got nothing to worry about anyways. I just don't want to do any sort of routing  :(
« Last Edit: December 26, 2012, 06:36:19 PM by Djentleman! »
darrenw5094
« Reply #4 on: December 26, 2012, 07:45:28 PM »
PRS short legs only.
Better off just changing them with BKP.
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
« Reply #5 on: December 26, 2012, 08:12:01 PM »
I would guess that long legs might fit a PRS with a stoptail bridge, but not a Cu24 with a trem bridge - because the bridge is lower so the pickup sits lower in the body.
But if I remember right, PRS' routing for pickup feet is pretty shallow so short legs are a better bet.
« Reply #6 on: December 26, 2012, 08:21:08 PM »
true
my long legged riff raff fitted properly in a stoptail mccarty, but the height screws didn't (that would require routing or cutting the screws)
I used the stock PRS screws, but they're a bit too short, so the pickup had to be set pretty high (which made it sound a little bassy, but amazing anyway)
if the Cu24 cavity is as deep as the mccarty's, maybe you won't have a problem if you cut off the BKP screws a bit
TheyCallMeVolume
« Reply #7 on: December 26, 2012, 09:55:52 PM »
Do you live relatively close to BKP so that shipping costs and wait time aren't so bad?
Djentleman!
« Reply #8 on: December 27, 2012, 12:12:11 AM »
Unfortuanately I live in Massachusetts so the cost of replacement would be just too much. Worst case scenario I'm throwing the PUP in my Ibanez JS1200...it ironically has a very deep routing in the bridge for an Ibanez.
I read on another forum I can actually just clip the screws a bit and that will allow enough room for the PUP to fit. Can anyone confirm or deny that? That might be the best solution I've got
« Reply #9 on: December 27, 2012, 12:37:46 AM »
I'd say just try it, first with the PRS screws - you already know they'll fit the routing, and maybe the pickup will sit low enough too.
And you could try measuring the depth of the routing to see what's the maximum length of screw which will fit, then compare that with the overall depth of the pickup.  Bear in mind the pickup rings add another few mm of "usable depth".
« Reply #10 on: December 27, 2012, 09:50:38 AM »
Long legs didn't fit the bridge position of my '09(?) McCarty, so PRS may have changed the dimensions of the cavities over the years.  The neck cavity was fine as it was deeper than the bridge...
TheyCallMeVolume
« Reply #11 on: December 27, 2012, 02:11:05 PM »
Like Philly says, I'd try it.
I love your name by the way, I've yet to see that! Very clever.
Djentleman!
« Reply #12 on: December 27, 2012, 03:46:27 PM »
^Why thank you!  :D
So my solution ended up being...buying a calibrated set with the appropriate leg lengths. I'm going to end up putting the original Aftermath I ordered into my Ibanez. The only thing I'm bummed about is that the Aftermath with the long legs has a Battleworn cover on it and I really wanted to put that in my PRS (yes, metal PRS  :harp: ). I've been looking up how to take off/put on covers, but the Battleworn cover seems different than say a Les Paul nickel cover. Should it be the same sort of thing - IE, soldering off the cover, wax bathing the PUP and re-installing/soldering on the cover?
Also, thanks for the help everyone who's replied, much appreciated!
« Reply #13 on: December 27, 2012, 04:09:37 PM »
Replacing the battleworn cover should be same process as replacing any other metal cover, but I believe the black coating on those pickups is quite soft, so you might want to go easy heating it and cleaning off excess wax etc, or it may end up looking more battleworn than you wanted....
Djentleman!
« Reply #14 on: December 27, 2012, 04:17:57 PM »
Lol, that would be bad... Anyone know if you can just buy the covers separate from the PUPs? It'd be much simpler to just put a cover on than remove a cover and put it on another PUP. I've found mixed results so far from Googling whether or not BKP does this
