Recording a band
Started by booboo_bass, February 26, 2006, 09:18:09 PM
booboo_bass
What sort of equipment do people here use to record their bands or anything with multiple tracks? What sorta methods do you use to mic up the drums etc...
thanks
Paint it funky
Floyd Pepper
If you're going to mic up drums you really need to go to a studio as it will have isolation rooms, lots of mikes and a mixer with a stack of inputs.  Doing it yourself will cost a small fortune to buy the necessary equipment.
We used to record rehersals with a Shure SM58 into a 4 track tape player.  Results we OK.  Better than a ghetto blaster's built into mic.
Live we used to record with 2 pizo mics on the floor into the 4 track.  The pizo gave better results but we had to borrow them.
Mother's Milk.  Mullard.  Cornford.  Mmmmm....
There are as many different ways to record a band as there are bands! Every band has a different method which works for them best.
May I ask: what is the purpose of the recording? If it's to sketch ideas, and audio quality just has to be audible, then you really don't need a multi-track recorder. However, the more flexability you have the more potential for better sound. I say "potential" because there are PLENTY of amazing albums which have been recorded in mono or stereo as a one take, or even stereo direct-to-disk. (That's when the mic feeds go straight to a cutting lathe)
My second question for you is: what is your budget? Do you already have the gear you will be using, or will you be renting/buying it?
Last question: Who will be doing the actual recording, and how much experience does that person have? I'm assuming it's going to be you or another band member.
I'm not a recording engineer by trade, but I've lots of live mixing experience, and I produced/recorded my band's last album.
Here are a couple of mic'ing schemes I like to use for recording my band live:
THE 1-MIC SOLUTION
One large diaphragm condenser right centered against the band, about 6-7' AFF.
THE 2-MIC SOLUTION
Two large diaphragm condenser mics in an X-Y pattern, or on a stereo bar, facing the band, 6-7' AFF.
I've got very good results with just 2 mics.
A SIMPLE 6-MIC SOLUTION
This is a mixture of close-mic'ing with one room mic.
Mics A+B = Over the drum kit (aka, overhead mics), about 7' AFF. You will have to work on the placement so that the mics get all the toms, cymbals, as well as having the snare drum be centered. You can then pan them apart until they have a nice stereo spread but don't have a "hole" in the center.
Mic C = Kick drum
Mic D = Guitar Stage Left
Mic E (if needed) = Guitar Stage Right
Mic F = Room mic for bass and vocal PA.
