Author Topic: Session Amps - awesome  (Read 8315 times)
Elliot
« on: February 27, 2006, 09:52:49 PM »
I just had my 20 year old Session Rockette 30 repaired by the good people at Andy's and all I can say is wow!
It has been in my Dad's loft for 15 years with a broken powerstage - now it's fixed and despite being mosfet powered has all the richness and warmth of a valve amp.  In particular my Mother's Milks have that Fender 'spank' tone on the cleans and the Mississippi Queen has a fat jazzy sound.  Shadows and surf stuff just rolls out of the clean like it was a Vox or Tweed Fender.
OD channel - the mule sounds very AC/DC and the MQ very Robben Ford (I have a Esprit which is RF's guitar).
Are modern Sessions this good?
Tinus
« Reply #1 on: February 27, 2006, 11:06:16 PM »
Guitar Magazine (UK) had a feature on Stuart Ward, the man behind Session, a few months ago. He also owns the new Award-Session company. I found his views on the transistor vs. valve debate refreshing (stating we basically tend to compare high-end valve stuff with low-end cheaply made transistor gear). As he is still the main tinkerer behind the newer amps I presume the quality should be pretty much equal, although I never heard a newer one. I am familiar with the sessionettes 'though and always thought of them as the most musical tranny combos out there.
HJM
« Reply #2 on: February 28, 2006, 08:11:52 AM »
A lot of jazz players love transitor amps. The way Mosfets work is very similar to a valve power stage - just they're expensive and most solid state amps don't use MosFets for this reason :(
The amazing Phil
« Reply #3 on: February 28, 2006, 08:55:27 AM »
What are mosfets?
Tellboy
« Reply #4 on: February 28, 2006, 05:22:37 PM »
Quote from: The amazing Phil
What are mosfets?
It's a looooong time since I did my HNC in electronics but mosfets are "metal oxide semiconductor field effect transistors". Used a lot in integrated circuits. Said to have a more pleasant valve-like sound than standard transistors when used in guitar amps but more expensive.
I played in a band where the other guitarist had a Session combo - it had a very good sound for a transistor amp.
« Reply #5 on: February 28, 2006, 06:41:10 PM »
My car stereo has a mosfet. Sounds way better that a normal tranny.
I tried some Marshall mosfet amps but boy do they suck.
Kilby
« Reply #6 on: February 28, 2006, 07:18:32 PM »
Mosfets are used in amp simulators too.
HH used to do some nice mosfet amps in the 80s and I think Trace Elliott often use mosfet
Not quite as nice as valve but very robust and reliable
Rob...
Goodbye London !
