Quote from: Lucifuge on February 01, 2013, 09:57:36 PM
Is that the alnico magnet Legend? I was thinking of trying one, but I think it will not have anywhere near as much body & depth in a small 1x10 as in that cab which looks pretty big.
Yep, it's kind of a modernised version of a P10R if you believe the blurb.
I've read that they can be a little lacking if used on their own in smaller cabs. But pairs or quads in bigger cabs get very good write ups. It also helps that I got them stupidly cheap. Though that wasn't the main reason I got them. Will be interesting to hear them cranked tomorrow!
The cab is a little larger than he'd normally do a 2x10 as I wanted to run it on it's side and not look silly being narrower than the head. So it's wider to match the head.
Quote from: TheyCallMeVolume on February 01, 2013, 09:45:04 PM
So you're fond of 10" speakers?
I am now! I fancied a bit of a change. Sold my 1x12 with a plan to go 2x10.
The other things I'm having made are going to be a pair of 1x10 combos, one with my Goldstar in, the other with a matching Goldstar power amp. That way I can run them as a stereo pair. The reason I'm going 10" in those is purely to keep them small as space is tight. I've got a pair of Ragin Cajuns for those, I heard one in Tom's Princeton and thought it sounded brilliant. Apparently it loses it a bit when dimed, but these are home use, low volume jobs only, and at that sort of level it sounded marvellous.
