Author Topic: Finishing guitar Body with Stain/Dye  (Read 23125 times)
Keven
« on: February 12, 2013, 01:25:25 PM »
Hi Guys,
i'm planning to take on a warmoth tele build project. i'm not a particular expert at finishing but this is a guitar i'd like to keep and achieve a kind of beat up look over time.
is there anything wrong with just dying the wood without any gloss or finish? is there a possible problem with humidity and so on if i don't seal the wood?
thanks!
My BK's:
C-Bomb Set / Blackhawk Bridge
Holydiver Set/ BG50 Set
Toe-Knee
    • DIY Audio
Re: Finishing guitar Body with Stain/Dye
« Reply #1 on: February 12, 2013, 04:45:34 PM »
Hi Guys,
thanks!
I tried this in the past against WezV's advice and it ended up really patchy and dull looking without any kind of clear on.
Your case maybe a little different though as this was basswood and it just soaked right in and dried really fast so it was virtually impossible to get a consistent finish.
http://WWW.BACKLINE.TK
Non Biased Guitar Forum
http://fret.boards.net
« Reply #2 on: February 12, 2013, 05:15:59 PM »
I haven't tried, but I imagine there must be an issue with the colour going really dark where it soaks into the end grain?  I don't know how to avoid that, but maybe it doesn't matter if you ultimately want the guitar to have a beaten-up look.
Maybe some kind of oil (Tru-Oil?) finish would be better than stain/dye?
Keven
« Reply #3 on: February 12, 2013, 06:20:01 PM »
I was looking at the tru oil option as well. the finish would be something like a yellowed tint dye not unlike maple necks, so nothing really crazy, plus it's on ash.
either that or i bite the bullet and pay for the clear nitro satin finish at warmoth..
My BK's:
« Reply #4 on: February 12, 2013, 06:33:55 PM »
I have paid for Warmoth to finish a body..... once.  And they did a very good job.
But generally I buy ready-painted showcase items, it's so much cheaper.
soul7
« Reply #5 on: February 13, 2013, 11:55:54 PM »
Hi Guys,
I'm planning to take on a warmoth tele build project. i'm not a particular expert at finishing but this is a guitar i'd like to keep and achieve a kind of beat up look over time.
thanks!
You definely need to apply a sealer. I use Behlen or Mohawk vinyl sealer in aerosol cans or you can mix shellac and denatured alcohol 50/50 ratio as your sealer. You can then actually add you dye to the sealear and begin shading with that combo as well until you reach you desired color/ tone and then finish off with your topcoat of choice. I prefer nitrocellulose. Good Luck! 8)
King Zog of Albania
« Reply #6 on: February 14, 2013, 01:04:17 AM »
« Reply #7 on: February 14, 2013, 09:14:23 PM »
well i am hearing good things about wudtone despite the odd first post :?
if you just stain wood it will turn dull as soon as dry.   but a coat or to of oil will bring the colour back instantly and seal it all in and you can still flat it off for a non-gloss finish
this is the look you can expect with just stain.  its a not quite done look because its not quite done
http://news.baileyguitars.co.uk/wp-content/uploads/2010/08/6-Cherry-red-stain-is-applied-e1282173240898.jpg
http://crimsonguitars.com/workshop-diary/images/stories/food/150809/14.JPG
just no vibrancy at all, and the stain will rub off and transfer to clothes at this stage
here is a black oil one i am in the process of doing.  wood has been stained black and had a few coats of oil applied
very black
bit of light on it
this is before a more involved process to get the finish exactly as i like it - but it shows the depth of colour/stain well.
« Reply #8 on: February 15, 2013, 12:26:04 PM »
I have now finished a mahogany strat body, and parts of an oak floor using dye, oil and then wax.
i've found the whole process to be pretty straightforward and i've been happy with the results. the oil is what seems to bring the magic to the finish - depth and lustre.
Keven
« Reply #9 on: February 19, 2013, 01:58:00 AM »
Y'all will be disappointed but i decided to go with a showcase stock clear gloss finished body and neck. i work at a remote site 28 days and have 14 days off so if i wanted to take the tele with me on the next work shift that was the way to go.
the good part is that it's going to be home tommorow and i'm home on the 28th so once i get there it's all "painting by numbers" as far as assembling the tele but with premium parts and still way much less than what it would cost me for an off the wall U.S.A Ash Tele with BKP's :)
PS: went for the vintage body with the square jack end and the really thin bakelite pickguard.
considering dishing out for a callaham 3 saddle bridge. i have a gotoh 6 saddle bridge coming in from warmoth. is it worth the change?
My BK's:
