Wiring Issue Les Paul Epiphone Custom
Started by monty, March 02, 2013, 08:55:50 PM
monty
I have fitted a new pair of bareknuckle PUPS - I have had some issues with the wiring - the wire from the 3 way toggle switch has three cores - white / red / bare
Can anyone tell me which is which for the neck and bridge pick ups - currently the toggle isn't working correctly
Thanks
IbbySabre
#1
I actually ended up wiring an Epiphone Les Paul back to front so the switch was opposite. If you find the bridge is the neck, and vice-versa, just flip the switch upside down. I actually like the switches in opposite positions :) I wouldn't call myself an expert on guitars, so what I just said may be totally different to what you meant. If so, I apologise in advance.
monty
I dont think it's as simple in this case .......
The toggle changes the from neck to bridge and does seem the wrong way round...... however when I have the switch in the middle I would expect both volume pots to have an effect and only one works
And yet when the toggle is either all neck or all bridge the volumes work ?????
I have also added a coil tap to split the pups - I now have two volume and one tone with push pull for the coil split
Thanks
IbbySabre
The exact same thing happens with my LP. When both pickups are activated, either of the volume pots will control both pickups at the same time. If this is a problem, I'm assuming there must be a way to wire it differently.
There is obviously something miswired in your guitar. You need to approach this systematically. Do you have a multimeter? If not, that would be the first thing to get - otherwise it is all guesswork.
If you don't have a multimeter, the best option is to start with a Les Paul wiring diagram - they are easy to find on the internet.
Still I strongly advise to buy a multimeter - I could not do any sensible troubleshooting without one.
