Humbucker bridge spacing question for PG Blues pups
Started by ArcherDay, March 08, 2013, 11:13:26 PM
ArcherDay
Apologies in advance as I'm sure this has been asked many times, but I want to get it right... I made the following measurements at the bridge site of my guitar... Do I want 50 mm or 53 mm bridge-spaced PG blues humbucker? Guitar is an LP copy with a tune-o-matic type bridge and stop piece.
1: measure E-string to E-string on the bridge itself: 51.5 to 52.0 mm
2: measure center to center of E-screws on current bridge HB cover: 52.0 to 52.5 mm
3: measure center to center of E-screws on the bridge itself: 52.0 to 52.5 mm
Based on above, do I order 50 or 53 mm ?
Thanks alot!
Marco78
bandmaster188
#2
les paul types are usually 50mm, but going on your measurements i'd say you need a 53mm. its not really gonna affect the sound though, its more a cosmetic issue.
gibson brought out  the 498t pickup which has 52mm spacing as the bridge spacing is wider than at the neck. so if you are buying a set, you could get  a 50mm for the neck and a 53mm for the bridge.
The swamp city shakers
Toe-Knee
I would measure the E to E spacing of the strings above the screw coil of the pickups to be 100% certain. Whatever that is go with the closest.
Edit: I see you have a bridge pickup E-E measurement. Did you measure this with the pickup in the guitar? And does it line up with the strings? If so i would go with 53mm
[url="http://www.backline.tk"]http://www.backline.tk[/url]
Non Biased Guitar Forum
[url="http://fret.boards.net"]http://fret.boards.net[/url]
