Author Topic: Set af Humbuckers for Jackson SL2H  (Read 4624 times)
MBKorn
« on: March 19, 2013, 07:14:47 AM »
Hi there
Im considering to put in two BKP ind this beauty.
Im considering to place a MM ind the bridge but would like some ideers for the neck. im thing of this: MM, AM og CS.
Im playing metal through a Peavey 5150 and would like a neck PU there is the perfect mach for my guitar, there will be tuned in C/B.
I have also a Jackson SL1 with a MM ind the bridge and my ideer is to use switch between the two guitars when i have numbers in the different tuning.
Like my sound when its not to hiss, like when there is some buttom and some punch. I like when the mid is a little scooped (make that on my amp).
Some ideers?
« Last Edit: March 21, 2013, 09:02:15 PM by MBKorn »
MBKorn
Re: Set af Humbuger PU for Jackson SL2H
« Reply #1 on: March 20, 2013, 04:28:54 PM »
hmmm
Can it really be, that no one have an opinion?  :(
littlemurph7976
« Reply #2 on: March 20, 2013, 04:38:39 PM »
These forums can be a bit slow sometimes, but people normally get around to answering you eventually.
If you like scooped mids then the MM or the CS should work for you. I have a Cold Sweat set in a Carvin DC727, and while I wouldn't describe them as 'scooped', they do have nice, smooth mids. I do tend to EQ in a tad more mids on my amp, and the bridge gets a nice crunch while the neck stays nice and smooth. The CS neck really is a good metal neck pickup, perfect for soloing and it also cleans up really well.
I've no experience with the MM, however, a friend had a set in an Ibanez RG and seemed to like them. They pulled of old school metal sounds and newer metalcore sounds (Killswitch, All That Remains type stuff) incredibly well. I've heard them described as being similar to an EMG 81, I don't know how true that is, but for scooped metal sounds, you can't really go wrong there.
So it all comes down to if you want some smoother mids in the CS, or totally scooped mids in the MM.
« Reply #3 on: March 20, 2013, 05:32:01 PM »
The CS-neck gets a lot of praise here being one of the best contemporary neckmodels. It is great for pristine cleans and fluid leads.
MBKorn
« Reply #4 on: March 20, 2013, 07:02:08 PM »
Thanks for your answer guys
But how will the CS fit in this guitar (maple neck-thru). Will it be to bright? And what would a good alternativ be?
About the MM. Is that the best choise for this kind of guitar or what would a great alternative be for the bridge?
thanks, michael
MBKorn
« Reply #5 on: March 21, 2013, 07:35:04 PM »
Come on guys ;-)
What would be a optimal choise for this kind of axe. Bridge: MM, WP (is it to dark?), PK (is it to bright?).
Neck: HD, CS or ?
Let me here some adwise on good combination
« Reply #6 on: March 21, 2013, 08:25:08 PM »
if you want clean neck tones as well as overdriven sounds them CS will be best and yes in my opinion fine with maple neck through.
for higher octane solo type stuff on neck you may prefer MM neck pickup - fat , fluid tones, but not so easy for great clean tones
MBKorn
« Reply #8 on: March 21, 2013, 09:02:44 PM »
http://www.youtube.com/watch?v=iUCDhvbQFmU
How is the CS compaired to the HD for the neck in this king of axe? And is there other great opportunties?
what about the bridge. What would a great PU be for som metal ... not to hiss in the sound. And what would a great set be (mixed is ok)?
Im very bad in descriping my sound, but hope you can give me some ideers anyway
« Last Edit: March 21, 2013, 09:06:12 PM by MBKorn »
MBKorn
« Reply #9 on: March 22, 2013, 03:26:20 PM »
Come on ... with so many posts, you may have somehing to come up with ;-)
Re: Set af Humbuckers for Jackson SL2H
« Reply #10 on: March 22, 2013, 04:20:12 PM »
I think you made a good choice with the Miracle Man for the bridge.
As regards the neck pickup: I would not pair the Holydiver neck with the Miracle Man bridge - it will be significantly lower in output. The Cold Sweat neck would be the better fit - it has the same magnet and wire gauge as the HD neck but more turns. So you will get a better output balance with the MiM and more mids to facilitate singing lead tones as well as good clean tones.
Other opportunities for the neck would be VHII (more vintage but a bit higher output than CS neck), Emerald (no personal experience with that), or Crawler (also very vintagey sounding).
The only combination I actually tried with the Miracle Man bridge is the Cold Sweat neck.
MBKorn
« Reply #11 on: March 22, 2013, 06:37:15 PM »
Did you tryed in a jackson?
What about the warpig or the painkiller in this kind of guitar?
How will the sound be
Thanks again
MBKorn
« Reply #12 on: March 23, 2013, 03:32:05 PM »
Im still looking
Dont know if is shold get: WP, NB, AM or another MM for my bridge.
I like my sound not to high hiss ... like it with some buttom. Im a little affraind of the AM, couse i maybe thing im to sloppy ;-)
I need to decide and to make a decision with neck to combine it with. Im still a little warm on the CS bu not sure
Sorry, but im very bad to descripe my sounbd pref. but hope you guys can give me some indput releted to the specifike guitar i have
« Reply #13 on: March 24, 2013, 03:02:05 AM »
Maybe a ceramic Nailbomb: supertight, good mids, not as scooped as the MM.
I would also have a look at the Blackhawk. Might fit your bill.
MBKorn
« Reply #14 on: March 24, 2013, 08:15:35 AM »
And how would a c-bomb/coll sweat sit in the particulare guitar?
