Author Topic: Bridge Humbucker advice  (Read 6582 times)
vega
« on: March 20, 2013, 06:29:31 PM »
Hi, I'm considering replacing the stock Gibson bridge pickup (490T) in my SG Special Faded (dated 2000) with something else, and wondered if anyone had anything they would recommend? Either companies or specific pickups.
Live, I play through a Marshall Vintage Modern 100w and use the "high dynamic range" channel as my main sound overall. I use an EQ pedal to quieten things every now and again, but mostly try and use the dynamic of specific parts to determine how much gain is needed, how hard to dig in, etc. I normally push my mids high (7-8) and roll off the treble (4).
In the studio, I use the same amp and guitar, but double almost everything with a Fender Jazzmaster.
The results can be heard here: http://carsonwells.bandcamp.com
In terms of the sound I'm going for with a new pick-up, I'd like something tighter from the guitar, with a little bit more definition, whilst keeping the overall dynamic control (if this makes sense?!). I'm happy with the way the amp sounds, but want a bit more clarity overall. I can achieve this at the moment by rolling back the pre-amp gain on the amp, but this inevitably makes things too clean and I'd rather avoid this. I've tried reversing how the current set-up works by rolling off the amp gain and boosting using an EQ, but it sounds too hyper/forced.
So far, I've been tempted by:
Di Marzio 'Super Distortion' - simply because Iain McKaye of Fugazi used one in his SG (played through a Marshall).
Bare Knuckle 'The Mule' - recommended by the chap who recorded the album posted above, and viewed as a half-way house between my current live sound and the overall sound of the album.
Seymour Duncan JB - recommended for being an 'all-rounder' and for easy availability/price.
Since these recommendations, I've checked out other Bare Knuckle pickups, with the Cold Sweat standing out for its clean sound. The biggest problem with the Bare Knuckle samples (and A LOT of YouTube demo videos) are their tendency to be heavily focused on one sound (metal, classic rock, etc.). I thought it was a good idea to post this and see if anyone had any experience/samples that didn't predominantly feature these genres.
Apologies for the long essay. Any help is really appreciated! Cheers, Ross
Re: Bridge Humbucker advice
« Reply #1 on: March 20, 2013, 06:45:48 PM »
If these three are the candidates you are comparing apples with pears. The low output Mule (alnico IV magnet) has a genuine PAF59-sound, the Super Distortion has a ceramic magnet with a dc-resistance around 13,5 k, the JB (alnico V magnet) is high output  with a dc-resistance of 16,4 k.
I can testify that the Mule is fantastic with a superb balance and complex, almost 3D-tones. I would also look at RiffRaffs, they particularly do very well in SG's.
BigB
  • Let's rock !
« Reply #2 on: March 20, 2013, 07:32:01 PM »
From what I hear of your album (which I so far really like, kind of reminds me of Fordamage   and Shellac), I think the Riff Raff set could work for you (the neck is wonderful too). You might also want to give the Rebel Yell a look for a bit more push and a more modern tone, but that a bit of a wild guess since I never tried it myself.
vega
« Reply #3 on: March 20, 2013, 10:50:54 PM »
Haha, I'll make no bones about it - I know next to nothing about pickups and have never changed them in any of the guitars I own or have owned. Is there any particular aspect of a ceramic or alnico magnet which would be conducive to the sound I'm after? I.e. should I be looking at pickups specifically with ceramic or alnico magnets? (Apologies if this is a daft question!) What difference does the dc-resistance make? (total noob :( )
Thanks for seconding the Mule. I'll check out the RiffRaff!
Thanks for listening and I'm glad you enjoyed it! :)
At the moment, I'm only really looking at changing the bridge pickup on my SG. This is mostly down to financial restraints and the fact that I barely play the neck pickup in this band. I checked out the Rebel Yell's sound clips yesterday and there certainly seemed to be a real body to it. I did wonder, though, whether it would be overbearing or forced; i.e. should I be prioritising clarity over body (something my amp gives me plenty of).
Many thanks for your help!
« Reply #4 on: March 21, 2013, 01:02:24 AM »
Ok, let's make things not complicated: alnico is warmer and organic sounding, ceramic is tighter and to my ears a bit colder sounding. All BKP's have tremendous clarity, dynamics and noteseparation, even with highgain.
When you after a more classic Les Paul/SG-sound, then look at the Mule or the RiffRaff. Those two deliver classic tones, but can handle a lot of gain very well. I can play everything with Mules, except for metal it is not the first choice. If you want a higher outpick pickup (which will hit the preamp of your amp harder) with a more contemporary tone look at Cold Sweats or (maybe) Rebel Yells.
BigB
  • Let's rock !
« Reply #5 on: March 21, 2013, 12:37:24 PM »
Telerocker's answer is as good as possible. For the kind of tones I heard on your record I think you want alnico pickups.
Overly simplified : higher DC resistance = more turns on the bobin = higher output level and less highs.
BUT this is really true only for the same wire gauge, magnet type, construction and winding, so you shouldn't pay too much attention to this, except possibly as a very wide and mostly unreliable indication of overall "hotness" of the pickup.
The neck Riff Riff is very clear sounding and articulate, with something almost single-coilish, and I definitely see how you could use it for your clean/crunch tones.
I barely used my neck pickups until I started using BKPs FWIW.
Clarity, dynamic, articulation and note separation are really BKP trademark so you shouldn't worry too much about this ;)
« Reply #6 on: March 21, 2013, 02:54:18 PM »
+1
« Reply #7 on: March 21, 2013, 10:09:42 PM »
mules!
just unwillingly sold a mule set for a friend
he's putting them in a really nice '82 greco sg standard
I had it in a jap hurricane lp copy (installing my spare vhII set now)
you'll find lots of great mule clips on players section, but mostly in les pauls and PRS's
here's a couple sg clips, but they're in much higher gain levels than you use
https://soundcloud.com/tom_the_beast/170812-2
https://soundcloud.com/tom_the_beast/sounds-like-clutch-2
the mules will do your thing in a similar way to the 490's, but with greater clarity and nicer organic detail
but if you want a more spanky and defined response, the riff raff is the way
cool band, by the way
« Reply #8 on: March 21, 2013, 11:19:30 PM »
Whilst I defer to the other guys' excellent recommendations, just going back to your original post:
You mentioned you liked the sound of the Cold Sweat (bridge, presumably), which no-one has followed up.  I just wanted to say that the Cold Sweat set is excellent in SGs, lots of tightness and clarity from the bridge model and a much warmer, sweeter tone from the neck model.
The bridge is ceramic, though, and I'm sure the guys are right that alnico is a better match for your style.
vega
« Reply #9 on: March 21, 2013, 11:46:35 PM »
Many thanks for everyone's responses, I really appreciate it.
I've decided to ditch the Seymour Duncans and Di Marzio options. After visiting my local guitar shop and having a look at the Bare Knuckle stock they had in, and weighing up the responses in this thread, I'm convinced that Bare Knuckles are the way to go. Clearly, it's between The Mule and the Riff Raff. I'll have a look around the clips online and then place an order early next week. I'm even tempted to go the extra mile and get The Mule in the bridge and put a Riff Raff in the neck (and take out the EQ pedal out altogether...).
Thanks again, dudes! :)
Philly Q - Thanks for your post (I typed out the above before seeing your post, sorry!). While I did like the Cold Sweat, I'm tempted to stick with The Mule or Riff Raff in the bridge, but will certainly consider the Cold Sweat if I change the neck pickup too.
« Reply #10 on: March 22, 2013, 01:27:26 AM »
the vhII has a quite similar voicing to the cold sweat, but less 80ish sounding
punchy bass and focused and detailed top and more controlled midrange
lot in common with the riff raff as well, but slightly more powerful
« Reply #11 on: March 22, 2013, 01:31:44 AM »
I'd do the exact opposite and have Riff Raff bridge, Mule neck, but fair enough if you like a bright neck pickup.  :)
« Reply #12 on: March 22, 2013, 02:11:42 AM »
I second this, or opt for a calibrated Mule-set.
TheyCallMeVolume
« Reply #13 on: March 22, 2013, 01:42:02 PM »
I think the RR bridge can't be beat! I'd go with the RR/Mule configuration.
BigB
  • Let's rock !
« Reply #14 on: March 22, 2013, 07:40:35 PM »
As someone that likes a warm bridge and a clear bright neck I think the Mule bridge / RR neck  combo could be the ticket :mrgreen:
You may want to AskTim(tm) before placing your order - the guy really knows its products.
The Cold Sweat neck might be way too powerful to match a Mule or RR bridge.
