disconnect the tone pot
Started by MBKorn, March 23, 2013, 02:15:05 PM
MBKorn
Hi and thaks for your reply. Just a quest: how much will have to say that i buy the BKP 550k pots a replace them with the 500k i have in my guitar now? Is it just a wast of money or?
Thanks, Michael
As a rule of thumb, a higher resistance pickup goes well with a higher resistance pot. But the difference of say a 480k pot and a 500k pot are nuances - it's not a make or break thing. You will hear a bigger difference if you exchange a 450k pot with a 550k pot. Keep in mind that the tolerance of such pots is usually 20%, i.e. a 500k pot could be anywhere between 400k and 600k (usually lower than 500k though)! Some manufacturers specify closer tolerances but that will trigger an upcharge.
If your pot is working fine, i.e. no dead spots in the taper, no scratching I would keep it. If it has issues I would buy the BKP 550k in a heartbeat.
MBKorn
But a 550k wont make my guitar sound to bright? (Jackson SL2)
Does it sound too bright now? If yes, stay away from the 550k - if at all it will make the guitar even brighter.
Does it sound a bit too dark right now? If yes, go for the 550k.
Does it sound right to you as it is? Leave it as it is.
