disconnect the tone pot
Started by MBKorn, March 23, 2013, 02:15:05 PM
MBKorn
Hi there
On my Jackson SL1 i have disconnectet the tone pot, so i only have the volume connectet.
I never have used the tone-kontrol and the volume-kontrol was sitting in a stupid position, so i disconected the volume-button and now use the old tone-pot as a volumepot and going without tonepot at all.
Do you see a problem in this modification?
Ore is there something a should be ware of?
I have a Miracle man in the bridge
thanks
Toe-Knee
I personally prefer the sound of guitars without a tone pot but i also prefer 1M volume pots especially with the miracle man. I find it tighter and a lot more cutting. You also get a bit more high end detail coming through which can be a bad thing if you have a bright amp.
[url="http://www.backline.tk"]http://www.backline.tk[/url]
Non Biased Guitar Forum
[url="http://fret.boards.net"]http://fret.boards.net[/url]
wolfenstein
There should not be a problem...Unless you use it with capacitor which is usualy aded to tone pot...Also slightly difference could be between audio /used as volume/ vs linear /used as tone/...If you don“t rolling back volume pot for cleans=no problem...
have CWP,MM...had AM,CS,VHII,NB,PK,HD...
Marco78
I had this modification on bridge pickups (without tone), but this pickup was shrill and unusable. Now ths problem is disappeared.
timmy_b
I would be very surprised if both pots aren't identical in rating and taper if they are the original components. The tone pot with it's associated capacitor removed will work just fine
Hi all, yes, it's another Tim! I'll be here to answer any questions you want to throw at me, here or via [email]sales@bareknucklepickups.co.uk[/email]
MBKorn
#5
Hi, and thanks for answeres
I kan se that my "new" volume-pot is 500k ... the one there is placed at the disconnectet tone is 250k. So i think my tech have changed them around or?
There is still going some wires to the ton-pot, there is disconnectet. Is that normal? (i dont want to use it at all)
And about the capacitor. Is that such a green think, there is put on the top of the pot. I have such thing, there is only solered with one leg.
Would it be a good ideer to buy another pot for my volume, to get the best sound out of my MM - and would it be the same pot i should use, if i get a c-bomb, CS ore something else to put in the guitar?
On the picture is the disconnectet "old volume, now tone" (250k) to left and the "now volume" (500k) to right.
Hope you can help again, thanks Michael
timmy_b
#6
We always recommend a pot of at least 500k for humbuckers, the 250k will dull your top end a fair bit. Check out our 550k custom CTS pots!
Also, yes if you want to use only 1 pot and you have a correctly valued pot to do that, there is no reason to not rewire it for that purpose and completely disconnect the other
There is no technical disadvantage at all - apart from the fact that you no longer have a functional tone control. It's all personal preference - if you don't need the tone control and the volume control was in your way before, then you did the right thing for you. And it's easy to undo it if you ever want to sell the guitar in it's original condition or want the tone control later.
TheyCallMeVolume
I'd say good call, I really don't like using the tone control at all either. I was thinking of turning into something I'd use, maybe a boost or something.
MBKorn
Alex
My experience in doing this have ranged from "almost no difference noticeable" to "big difference easily audible".
I normally leave a tone pot on, because it fattens the treble strings up. The high E-string can thin out and become harsh without a tonepot, depending on of course several other factors as well.
MBKorn
#11
But will it do any difference if the pot is opend up anyway?
Is there a way to have the tonepot still on, but make it so you can turn it up and down (an no ... dont want to glue the button :D)
And i i want to buy a pot from here, so i have the optimal one to use for my volume, witch one to choose for the Jackson SL2?
Alex
Quote from: MBKorn on March 25, 2013, 02:09:10 PM
Yes, with a normal pot it will. There are some special "no-load" tone pots, which I know are sometimes used by Fender, but I've never seen one in any place.
On the other hand, some players will solder a capacitor on the volume pot to simulate the extra load of a tone pot.
It should really be seen as a bit of fine-tuning, as it really can vary a lot between guitars. That's what I was trying to convey in the message above. In other words, experimentation is key.
MBKorn
Thanks a lot for your answers
What capacitor should i get, to simulate the load from a tonepot?
I would get a 0.022uf (=22nf, sometimes labelled "223") capacitor (the voltage rating does not matter) and a 470k or 510k resistor. Solder one end of the cap and the resistor together and tape the connection. Then solder the other end of either the cap or the resistor to the input lug of the volume control, and the other end to ground. There is your fully turned up tone control.
