Author Topic: Looking for some PU for my LesPaul J. 2013  (Read 2861 times)
Progression
« on: March 24, 2013, 06:19:32 PM »
Hey,
i am looking for a BareKnuckle PU for my LPJ 2013. I got in my second guitar (LP Epi), Seymour Duncan SH4 and SH6 like them but i want in the LPJ something different. Should be a passiv PU, with a good punch, open, and no agressive highs but also not too covered.
I am playing, progressiv metal, should be also great in clean parts.
Do you think the holydriver could be a good choise for the neck position or any other advice?
DavidPRS
Re: Looking for some PU for my LesPaul J. 2013
« Reply #1 on: March 24, 2013, 09:49:34 PM »
Holy Divaaaauh.
DavidPRS
« Reply #2 on: March 24, 2013, 09:59:04 PM »
Your LPJ has 498 bridge right? I'd just put 500k pots and new caps and you'll be all set. Your LPJ has 300k pots from the factory. 500k will make a huge difference and open up those 490's. You do mean "LPJ" model and not the LP "Junior" model right?
https://www.martinsixstringcustoms.com/store/prewired-guitar-electronics-harnesses/prewired-les-paula-wiring-harness/prod_9.html
Progression
« Reply #3 on: March 24, 2013, 10:30:59 PM »
Yes i got the lpj.
« Reply #4 on: March 24, 2013, 11:06:08 PM »
Anyway, if you want to switch pickups, look at the Holy Diver/Cold-Sweat-neck combo.
If your amp is highgain you could also consider the Black Dog, maybe in combination with a booster. The BD is open,  has a bit more mids then classic PAF's and is tight enough for metal. Often recommended for sevenstrings too. Should work fine a Junior too.
« Reply #5 on: March 25, 2013, 05:42:15 AM »
the 498t still sounds shitety with 500k pots  :shock:
Progression
« Reply #6 on: March 25, 2013, 06:43:35 AM »
the 498t still sounds shiteety with 500k pots  :shock:
this is what i think too, now it sounds like there is no real pressure/depth sounds empty. Sure a poti change will be too a fine thing, but i think mor highs and openness will be not the solution of this.
Do you think i can use the holy driver in the bridge and the org. gibson 490r in the neck together?
