Author Topic: Help with ID  (Read 1518 times)
DalyTek
Help with ID
« on: April 20, 2013, 07:54:11 PM »
I am looking to buy a (used) bridge Holydiver pickup and am a little confused as to how to identify if it's the correct pickup.
The one I am looking at has the braided 2 conductor wiring, and all the other Holydivers I see are 4 conductor with the black plastic wrap.
The resisitance is ~15.2K if that helps.
Thanks for any help!
Andrew W
Re: Help with ID
« Reply #1 on: April 20, 2013, 09:56:19 PM »
BKP offer the Holydiver (and all their humbuckers as far as I know) in either braided or 4 wire format so you could get a Holydiver with braided wire. The main site says that Holydivers are around 15.9KΩ but they do vary a bit from individual pickup to pickup so the one you're looking at is in the ballpark. There's nothing about what you've described that says it definitely isn't a Holydiver.
DalyTek
Re: Help with ID
« Reply #2 on: April 20, 2013, 10:32:10 PM »
I just double-checked with the seller, and he is certain it is the Holydiver.  Based on the info he provided and I got on the BKP site (as well as your input, Andrew, thanks!) I went ahead and bought it.  This is my first BKP, and I researched and listened to lots of tone samples before deciding this is the pickup for me.
Alex
Re: Help with ID
« Reply #3 on: April 20, 2013, 11:40:57 PM »
The impedance can vary quite a bit.
Re: Help with ID
« Reply #4 on: April 22, 2013, 06:49:17 AM »
the dc reading will vary even in the same pickup with the same multimeter
I had a cold sweat that eventually read around 14.3k, but sometimes it would read up to 15k
the holy divers I had were usually around 16k, but they also would should a bit less or more sometimes
  • Brokeback is back
Re: Help with ID
« Reply #5 on: April 22, 2013, 07:19:07 PM »
Tell us your impressions on the pickup when you get it installed and have had some playtime with it.
