Author Topic: Flaking frets  (Read 6912 times)
Jamie
Flaking frets
« on: May 07, 2013, 05:06:04 PM »
Its a NGD today. Just had a quick play around on this...
It feels very nice to play, the scalloped fretboard makes bending and vibrato so easy. However I felt the strings catch on some of the frets and upon looking I saw this...
It looks like the coating on a lot of the frets seems to be flaking away. Has anyone seen this before? It looks like it is going to be an expensive fix.
Kevin Bond sig RR Jackson        Charvel SoCal
Ibanez Jem BSB                       Jeff Loomis Sig 7 String
Warmoth Strat                         ZW Bullseye Epi
Orange #4 TT and Cab
blue
Re: Flaking frets
« Reply #1 on: May 07, 2013, 05:16:32 PM »
it looks to me like whoever lacquered the fingerboard left the same finish on the frets too.  i could be wrong, but i would say a fret polish with some very fine steel wool will take it all off and leave your frets just fine.  just remember to mask off  the wood first, and either tape up or remove the pickups as it's "not ideal"  to get steel fragments in there
Keven
Re: Flaking frets
« Reply #2 on: May 07, 2013, 05:33:03 PM »
I had this happen on my warmoth tele build. the finish was a poly instead of nitro, and as i bend the frets i could see flakes of varnish wearing off the frets. they tear off easily so i don't think anything as major as steel wool would be needed, i took mine off by playing a whole lot, and then by the next string change i just brushed the frets with a toothbrush and the rest kinda just tore away. it was a bit of a frantic toothbrushing however so maybe steel wool is faster in that respect but all the preparation makes both ways even.
a pro should chime in on this!
My BK's:
C-Bomb Set / Blackhawk Bridge
Holydiver Set/ BG50 Set
Re: Flaking frets
« Reply #3 on: May 07, 2013, 05:42:32 PM »
I can't see the pictures, but if it's a maple board it's perfectly normal for them to spray lacquer over the frets.
You'd then expect someone to have scr@ped it off while doing a final fret dress, but most of it'll come away naturally fairly quickly, it doesn't stick well on the metal.
I think Dan Erlewine (from StewMac) uses a special tool, made from a large nail with the tip ground down, to scr@pe off the lacquer.
TheyCallMeVolume
Re: Flaking frets
« Reply #4 on: May 07, 2013, 05:56:47 PM »
Press pretty heavy on the frets huh?
Anyhow, like everyone else is saying, my guess would be leftover lacquer, just find something to scr@pe it off with.
JJretroTONEGOD
  • JJ Retro w/Mule + BKP90
Re: Flaking frets
« Reply #5 on: May 07, 2013, 06:03:02 PM »
try and use a scalpel knife to gently scr@pe it away then clean it with isopropyl alcohol and cloth
Re: Flaking frets
« Reply #6 on: May 07, 2013, 07:19:48 PM »
http://www.manchesterguitartech.co.uk/images/nail-as-fret-scr@per.jpg
the pic/link wont work due to spam filter - change the @ to an a
it needs to come off and it clearly wants to come off.  scr@pe with modified nail or rub it with fine wire wool.   if worried you can mask off the board and score the seam between fretboard/fret, but often it isnt needed
« Last Edit: May 07, 2013, 07:21:29 PM by WezV »
Re: Flaking frets
« Reply #7 on: May 07, 2013, 09:20:01 PM »
Ah, that's probably where I saw it, maybe it wasn't a Dan Erlewine tip at all!
Presumably the iron nail is somewhat softer than the fret material, so it doesn't mark them?
Plenum n Heather
Re: Flaking frets
« Reply #8 on: May 07, 2013, 09:31:00 PM »
It's broken and should be sent to me for disposal. I am PM'ing you my mailing address. You will send it at your cost, of course, since I am doing you a favour.
You're welcome.
Jamie
Re: Flaking frets
« Reply #9 on: May 07, 2013, 10:20:29 PM »
You're welcome.
Not a chance... I'm not paying postage, looks like Dmoney could maybe bring it to you for 'disposal'.
Thanks for the info eveyone, I feel like I have dodged a bullet there. I really dig in with my bends and vibrato so I think I will just play it until it comes off.
I have quite an important maths exam tomorrow but I haven't been able to put the guitar down yet, so its safe to say I am really happy with this one. Unfortunately I have convinced myself to carry out a one in one out system so I now have to decide which guitar will be on its way out  :(
Re: Flaking frets
« Reply #10 on: May 07, 2013, 10:59:09 PM »
Very noble!  :wink:
Good luck with the exam!
Plenum n Heather
Re: Flaking frets
« Reply #11 on: May 07, 2013, 11:01:43 PM »
Very noble!  :wink:
+1
Re: Flaking frets
« Reply #12 on: May 08, 2013, 09:21:01 AM »
it might have been dan, this is not a new trick.  iirc its not far off the way fender used to do it
