Author Topic: Versatile Set for Basswood 7-string  (Read 8471 times)
MerlinTKD
« on: May 13, 2013, 02:34:30 PM »
So I have an LTD M-207 (basswood body, rosewood fretboard, drop-G, 11-49+68 strings) with Painkiller's in it; it's been great, I love the sound, but I'm in a situation now where I need something a bit more versatile. My writing partner and I are exploring combining our styles to get something new: me bringing metal/prog, she bringing punk and New Wave (Thomas Dolby, The Cure). It's a lot of fun and we've come up with some fantastic ideas, but I'm becoming less and less satisfied with the tone I'm bringing to the table. Her tone tends to be dark, not crispy at all, out of guitars with PAF-style pickups, and the tones I can get with PK's in basswood just aren't mixing well.
There are lots of options, I know, but here's the rub: we're tuning down a full step, her a six-string in D standard, me in Drop-G. I'm not wedded to drop tuning, but I've written so much stuff that way already I don't want to necessarily rule it out for the future.
What I'm ideally looking for is a bridge pickup tight enough to handle the low G (likely ceramic, I imagine) that can go back and forth between modern metal and punk-ish rock, and a neck pickup that can go from jazzy (George Benson, Pat Metheny) to fluid prog leads (I'm assuming something AlNiCo). I love BKP's, not a fan of actives, so what can I replace my PK's with that will give me what I'm looking for?
LTD M-207: Painkiller bridge, Painkiller neck
Re: Versatile Set for Basswood 7-string
« Reply #1 on: May 13, 2013, 03:03:35 PM »
Firstly I thought was the Holy Diver cause it sits well in basswood and is very versatile, but after reading the rest I am thinking Emerald might be better. With that one you can get jazzy and fluent neck tones which can shred and sing and the bridge is tight enough I recon and with itīs brightness could sit very well with the darker, not crisp tone of your partner, adding in what she does not bring. It is also very versatile enough to handle modern metal (its somewhat of a favorite for that) and punk-ish rock.
Otherwise maybe blackhawks.
My thoughts anyhow, depends a lot on what exactly you think your sound needs compared to the PK and in relation to your partner.
MerlinTKD
« Reply #2 on: May 13, 2013, 03:14:26 PM »
Thanks Kiichi! The PK in my guitar is already pretty bright, or high-middy really, something darker but still tight (in the bridge) is what I'm hoping for. From what I've heard, the HD isn't very tight down as low as I tune, but I could be wrong! I was wondering about Nailbombs, or Black Dogs, or Riff Raffs.... just not sure at all! :lol:
  • Random Solution
« Reply #3 on: May 13, 2013, 04:15:22 PM »
Like Kiichi, my immediate thought was Holydiver but then I went off the idea when i read the rest of your post. My second thought was also Emeralds but my concern would be that the bridge would be too bright for basswood. I think the Emerald in the neck will certainly do what you want and is ideal in many respects but I'd be tempted to put a Black Dog to go with it in the bridge. That would give you a very versatile combination that will cope with your low tuning without being overly powerful. The Nailbomb could work but it is absolutely brutal even in alnico form and easily tight enough for your tuning. If you're after a very aggressive sound in the bridge it could work but I'd have thought a Black Dog/Emerald combo would be more versatile and more suited to your needs.
MerlinTKD
« Reply #4 on: May 13, 2013, 07:46:07 PM »
I hear you about the Nailbombs... I've heard good things about Black Dogs in extended range, as long as it stays tight that low. The Emerald seems awfully bright, I'm looking for something smooth in the neck, kinda the opposite of, say, Tosin Abasi or Tesseract. Maybe the Emerald is, I only have the official clips to go by. ;) I'm liking the idea, just wondering if the BD/Emerald is the way to go, or a BD set?
  • Random Solution
« Reply #5 on: May 13, 2013, 09:09:10 PM »
I originally bought an Emerald set but had to send the bridge back because it was too bright. The neck isn't anything like as bad and that's been a real keeper. It's my favourite neck pickup of all. The Alnico IV magnet in the neck makes it beautifully smooth and fluid as well as versatile. Previously the Cold Sweat was my favourite neck pickup but the Emerald is more versatile as it has much better cleans as well as a sweeter lead tone.
Zaned
« Reply #6 on: May 14, 2013, 08:11:07 AM »
PK is high-mid heavy, more than any other BKP. If you decide to go ceramic, the pickups with the least center mids are the Miracle Man and Cold Sweat. Their voicings are different, MM has a lot more low mids. Nailbomb and Aftermath have more center mids, while not being high-mid heavy.
Nailbomb was also brought up, here’s a clip of a Alnico V Nailbomb in a downtuned guitar 2 Channel Titan Amp - Detuned Demo w/Alnico V Bareknuckle Nailbomb
Be aware that Nailbomb and Cold Sweat are somewhat related. A ceramic Nailbomb is essentially an overwound Cold Sweat, which means that is has more mids and less highs than the Cold Sweat. The Alnico V Nailbomb naturally has a softer response and more mids than the ceramic version. Tight it is, still.
There are a number of pickups that can do what you want them to. As you already know :) So some tone references could work best.
-Zaned
Paths are for followers.
« Reply #7 on: May 14, 2013, 12:17:46 PM »
As per usual now I agree with Slartibartfarst42. The brightness thing you hear about the emerald is about the bridge, the neck is another monster. Really sweet, fluid, singing stuff.
On count of the bridge, if you want to go darker (expected you to do like one bright, one dark kinda combo, but you know both your sounds, also relating to amps and such better) the BD seems like a nice choice I must agree.
If you would like to go ceramic, I think I would prefer the CS over the MM for your work.
MerlinTKD
« Reply #8 on: May 15, 2013, 05:11:09 AM »
Thanks guys! This is really good info! I checked with Nick @ The Axe Palace, he's not big on the Black Dog in basswood, seems to be leaning towards the C-Bomb for the bridge. The biggest question I have about that is, will a C-Bomb be versatile enough for what I'm doing? Or, would the Cold Sweat be a better choice? Dark enough to blend better, for sure, but not too powerful?
Another wrinkle, I may have the opportunity to pick up an Apex 2 pretty reasonably; if so, the PK's would go in that mahogany body and let that be the drop-G guitar, and tune the basswood LTD either to A standard or drop A.
« Last Edit: May 15, 2013, 05:20:21 AM by MerlinTKD »
JimmyMoorby
« Reply #9 on: May 15, 2013, 07:31:52 AM »
Obviously versatile is subjective but the alnico nailbomb does blues to hair metal to thrash incredibly well best pickup ive ever played.  I cant imagine  a more versatile pickup very agressive but very responsive and clear.
I like the black hawk but i personally dont think its versatile. Great for full on metal but i must admit i dont play fusion so maybe thats where im missing out.
  • Random Solution
« Reply #10 on: May 15, 2013, 07:44:42 AM »
Interesting. I think the Nailbomb is very dependent on the guitar it's in. I tried the A-Bomb and it was the most aggressive pickup I've ever come across and no matter what I did, I couldn't get rid of the aggressive 90s Metal feel. At first I tried it in a maple neck-thru Jackson where it was awful and then in a PRS SE Custom 24 (mahogany body and maple neck) where it was a bit better but still too aggressive. I've found the Holydiver and even the Miracle Man to be far more versatile in both guitars.
Zaned
« Reply #11 on: May 15, 2013, 10:55:56 AM »
It probably just clashes with your guitar(s),amp and/or taste :) I originally took it out of my custom strat, as it had this edgy thing you mentioned. I replaced it with a HD, but recently I felt that the mids were TOO pronounced to my taste. I also felt that the guitar had become warmer after a few years of playing, now being a very balanced and clear instrument. I put the Nailbomb back in, and it just works. Yes it is aggressive, but that irritating edge is no longer there. I always loved the bottom end thump it brought. I also like a strat to be wild and fierce.
I know the CS for example is brighter than a NB, but it's not always as simple as that. The frequency response of a pickup is what it is, and sometimes it can emphasize some (unpleasant) frequency in guitars voice that can make it sound aggravating, even though some other pickup with more highs can sound warmer.
-Zaned
« Last Edit: May 15, 2013, 02:42:24 PM by Zaned »
  • Random Solution
« Reply #12 on: May 15, 2013, 01:40:15 PM »
It probably just clashes with your guitar(s),amp and/or taste :) I originally took it out of my custom strat, as it had this edgy thing you mentioned. I replaced it with a HD, but recently I felt that the mids were TOO pronounced to my taste. I also felt that the guitar had become warmer after few years of playing, now being a very balanced and clear instrument. I put the Nailbomb back in, and it just works. Yes it is aggressive, but that irritating edge is no longer there. I always loved the bottom end thump it brought. I also like a strat to be wild and fierce.
I know the CS for example is brighter NB, but it's not always as simple as that. The frequency response of a pickup is what it is, and sometimes it can emphasize some (unpleasant) frequency in guitars voice that can make it sound aggravating, even though some other pickup with more highs can sound warmer.
-Zaned
I know exactly what you mean. I found that the A-Bomb was just 'too much' yet I wasn't really against the core tone, which I recognised as very good. I just felt it needed to be toned down a bit and tamed so I'd be happy to try it again if i had something like a Les Paul as I suspect all that mahogany would help to take the edges off it in the same way your guitar has done so by mellowing over the years. I also agree about the Cold Sweat as unlike the Nailbomb, I really liked that one.
MerlinTKD
« Reply #13 on: May 20, 2013, 04:04:22 AM »
Hrm, interesting. I always learn so much here!!  :D
You guys mentioned particular guitars having particular frequency 'personalities', as it were; I've been messing around with this guitar a lot the last few days, paying really close attention to what it sounds like through a number of different amps as well as various amp models in my Mustang, and I've noticed that, acoustically, it's light and middy, and when plugged in (with the PK's) the highs and high mids get emphasized as well, but the lows are, well, loose. I'm finding the root of my problem is that, to get a tight sounding low G, the high strings are excessively edgy, and when I darken the high strings (via amp settings), the low D and G become bassy - warm, not truly muddy, but not tight.
So I'm starting to accept that perhaps I'm asking something of this guitar is doesn't naturally do well: being clear at a low tuning. As I mentioned before, I may be able to get an Apex2 reasonably, and if so will try THAT guitar in low G with the PK's (I hear they're fantastic in mahogany?).
In that case, what's the best sounding all-around pickup for a basswood 7 in standard tuning?
  • Random Solution
« Reply #14 on: May 21, 2013, 11:22:58 AM »
If I was simply thinking of a very versatile pickup that sits well in basswood, I'd undoubtedly say Holydiver as it's the most versatile pickup I've tried. If you still wanted something for low tunings, it sounds like your options are limited. The tightest pickups would be Aftermath, Nailbomb and Black Hawks but I think you may find the Aftermath too dry and surgical and the Nailbomb is absolutely brutal, even in alnico form. The Black Hawks may be worth a go as they seem very versatile and give you alot of the things you'd like about actives while keeping the characteristics of passives that you want.
