Author Topic: crazy new fuzion track BKP90 + Mule (featuring the Strymon Ola)  (Read 4070 times)
JJretroTONEGOD
  • JJ Retro w/Mule + BKP90
here's my crazy new fusion track...was in a weird mood all day and came up with this one:
https://soundcloud.com/bentyreman/24_05_13_master1
all the guitars featured are a JJ Retro using coil tap so it's a mule in the bridge using the bottom single coil, then other tracks use the BKP90.
Setup was the guitar into a strymon Ola' straight into the Focusrite ISA One DI input with the HPF engaged, this then goes into a mackie 820 onyx into an m-audio 192 PCI card inputs. NO EQ or compression on any of the guitar tracks.
I used Cubase 7 for all the drums, bass programming, mixing composing editing e.t.c. then wavelab 8 for some mix compression and dithering, hope you like it.
Ben.
« Last Edit: May 24, 2013, 03:52:17 AM by JJretroTONEGOD »
