Strat wiring question
Started by zeenrequiem, June 05, 2013, 08:28:47 PM
zeenrequiem
Hey all!
Question regarding wiring a nailbomb into an american stratocaster.
I have to admit i'm pretty new to the whole wiring process but so far I've determined where all the wiring should go from the diagram provided on the bareknuckle site. The only problem is i'm not quite sure what to do with the white and green wires. I'm assuming they will control the splitting of the pick up when the selector is set to position 2. So that should be a mix of the middle single coil pick up and the bridge, right? Currently I think the middle pick up is wired into the space on the selector that I need to put the green and white wires on. Should these wires be added or does this require a little bit of re-wiring?
I did a dry run on a guitar last night and removed a humbucker only to find that there were two wires just taped together and not actually soldered to anything. I'm assuming these are the same wires as the green and white ones on my nailbomb (differing colour codes). So in theory the pick up should work without these? I just won't have the split option?
