2 Hum, 1Vol, 4 Con, 5 Way Blade
Started by KennyG, June 09, 2013, 02:03:22 AM
KennyG
Is this possible to do? I Just received 2 4conductor black hawks and would like the wiring as follows.
1-Bridge
2-Bridge and neck coil tap
3-Both
4-Neck Coil Tap
5-Neck
Raymond
Yes you can if you use a super switch. You need to know what you want to use, the slug or screw parts, for the coil tap.
Check this website, they have some combos with a 5 way blade
http://www.guitartechcraig.com/techwire/diagindx.htm
