Miracle Man or Warpig?
Started by Guitar_Head, June 30, 2013, 01:02:21 AM
Guitar_Head
So I have a Jackson RR3, alder body. I have been doing research and have been pointed to the miracle man but I do want versatility. I want a tight bassy chug with screaming leads. I do want open sounding cleans and play in drop C mostly. I use high gain and play grunge/metal. What are your thoughts?
Guitar_Head
Also if I were to get the Warpig I would get the C-magnet, the Warpig also seems to have a lot better reviews.
darrenw5094
Possibly the Painkiller too.
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
the miracle man is very versatile
the nailbomb is plenty of bass as well
My thoughts on the Miracle Man bridge:
Tight bassy chug - tick.
Screaming leads - tick.
Open cleans - yes, if you include the option to use it as single coil or in parallel.
The Miracle Man is a fantastic pickup that will suit both your guitar and style. I've enquired about a Warpig a few times and based on everything I've been told by BKP, I think you'll find a C-Pig to be a lot less versatile than the Miracle Man. The A-Pig is rather more versatile but even then, it will always have that booming bass. The A-Bomb is tighter and more aggressive than even the Miracle Man but it doesn't give you that big bottom end like you get from the Miracle Man.
