thinking about a mule set or...
Started by JohnZAH, July 12, 2013, 05:46:34 PM
JohnZAH
a mule/abraxes for an Epiphone sheraton 2.
What do you think? I play rock n roll
John/ Shut Up & Deal
Well what comes to my mind when I hear rock n roll the mule certainly can handle very well. Since it goes up to hard rock and early metal sounds without problem too you´ll probably won´t need the extra hotness of the Abraxas.
You´ll get a very balanced sound and loads of versatility. That classic 59 paf sound does a lot.
Though if you want more info and more precise recommendations you´ll have to give us more info too.
For rock'n'roll you want the open, dynamic character of the Mule, which can go very heavy too if neccessary. I play everything but metal with Mules.
BigB
I'd probably favor low output pups for a semi-hollow to get more of the guitar's tone so I'd say Mule. FWIW you might want to consider RiffRaff too, got a set in my semi-hollow Hofner Verythin and they really rock (bright, punchy and focused, handle hi gain with no problem, and of course sound ace for clean / about to breakup and bluesy crunch tones).
JohnZAH
Yeah sorry about the vague details. I just didn't want the bridge to sound too "tiny" in comparison to the neck. I know how these semis can get very thick in the neck position. The mules seem very well rounded though.
BigB
Quote from: JohnZAH on July 12, 2013, 07:51:35 PM
The RR neck is quite bright so it doesn't get too thick wrt/ bridge, and while very jangly the RR bridge isn't thin - quite bright for sure but the low end is here too (as long as your guitar does provide it, that is). I've been using the Verythin as a backup for my NB-loaded SG in my now defunct alt/grunge/stoner band and didn't have to drastically tweak my pedals / amp EQ / gain settings when swapping guitars (in fact I never bothered changing anything when I had to swap guitars during a gig - just rolled down the bridge's tone a bit and dig a bit harder on the strings). But well, Mules are indeed a bit rounder / fatter (well the neck at least - I'll tell you more about the bridge by the end of the week-end ;)).
FWIW, Mule neck / RR bridge is one of Tim's favs for LPs, but I thing a Mule bridge / RR neck (anyone here ever tried this ?) could be quite interesting too, specially if your guitar tend to be a bit too thick on the neck (or a bit too thin on the bridge - usual half-full or half-empty bottle question).
darrenw5094
Have a black dog bridge and riff raff neck in a Tokai lp. Also a aet of mules in a Bacchus lp and a set of Abraxas in a gibson lp standard.
I would like the Abraxas bridge with a mule neck to give great rock tone.
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
braintheory
#7
I have a Cold Sweat neck in a Gibson Les Paul Custom 68 Reissue and I also don't care for it.
EDIT: Oops.  Sorry this was meant to go here: https://bareknucklepickups.co.uk/forum/index.php?topic=30248.msg390426#msg390426
Engl Artist Edtion
Engl Invader
Friedman Phil X
Gower Rockmonster
Mesa/Boogie Mark III Coliseum
Mesa/Boogie Mark IIC+
Peters FSM/Halo
Randall Thrasher
Rhodes Gemini
Wizard Modern Classic
JohnZAH
thanks for the replies! I'll have to consider a few options but I think as a right of passage as a guitarist, I should try a mule set.  :lol:
